Left hand thread nut for Pinnacle Bench Grinder
Metric or Imperial?
Roger Owen 509/06/2017 15:52:53
5 forum posts
I have a Pinnacle 6" bench grinder, bought around the early 1980's and I've lost the left hand threaded end retainer nut. Does anyone know what the thread is? Looks coarse, measures 13mm - but I wonder if it might be imperial. The thread on the shaft is 18mm long (7/10th inch) and over than length I count 9 thread ridges. Any ideas?
Journeyman09/06/2017 18:26:06
1257 forum posts
264 photos
Possibly 1/2" Whit which is 12 TPI roughly 2mm crest to crest.
not done it yet09/06/2017 22:02:13
7517 forum posts
20 photos
Two wheels? If so, remove the other side and check that?
Bazyle10/06/2017 15:27:00
6956 forum posts
229 photos
Measure again carefully. Likely to have been built for the American market where UNC 1/2 in has 13tpi.
John Reese11/06/2017 22:17:26
1071 forum posts
If the thread diameter is 1/2 inch I would bet the thread is 1/2-20. I have never seen a coarse thread on a bench grinder. No experience with bench grinders made to metric standards.
not done it yet12/06/2017 06:32:04
7517 forum posts
20 photos
Just a rain check.
How many valleys? Wondering here whether first ridge counted was number zero.
Edited By not done it yet on 12/06/2017 06:32:44
John Reese13/06/2017 03:17:32
1071 forum posts
Can you use a bolt of known pitch to check the pitch of your threads? Do you have a friend with thread pitch gauges?
Roger Owen 530/06/2017 20:21:34
5 forum posts
Posted by Journeyman on 09/06/2017 18:26:06:
Hi John,
You could be right there. I got a gauge which only goes down to 13 TPI - it's close but I think 12 would nail it.
Roger Owen 530/06/2017 20:25:34
5 forum posts
Thanks for all the responses. Next Question - bearings are a bit dry. Should I attempt to pack with grease, straight 30 SAE oil, heavier oil (EP90) - or does it not really matter.
