Sieg SX1L on steroids
John Rudd09/06/2017 12:26:34
1479 forum posts
Worth looking at.....
http://www.ebay.co.uk/itm/Sieg-SX1L-Milling-Machine-And-Drill/122506712438?_trksid=p2047675.c100009.m1982&_trkparms=aid%3D888007%26algo%3DDISC.MBE%26ao%3D1%26asc%3D43782%26meid%3D466f75247f7e411f9ad65399da697a11%26pid%3D100009%26rk%3D1%26rkt%3D1%26sd%3D122535843230
Edited By John Rudd on 09/06/2017 12:29:44
MW09/06/2017 13:08:08
2052 forum posts
56 photos
Very similar to my WM16, although I kept the gears rather than switch to belts and the motor is mounted on a much simpler angle bracket and plate configuration! TEC motors if i'm not mistaken. I call mine the frankenwarco.
Michael W
Edited By Michael-w on 09/06/2017 13:09:57
Neil Wyatt09/06/2017 14:30:17
19226 forum posts
749 photos
86 articles
Posted by Michael-w on 09/06/2017 13:08:08:
Michael W
So why haven't you sent me a short write up, you know I love covering frankentools in MEW!
Ian P09/06/2017 15:02:28
2747 forum posts
123 photos
belt drive -1.jpgThese pictures are of a Clarke CMD10 that I converted to belt drive. I started with the standard motor but then decided that the motor would be better if it counterbalanced the head weight if it was at the rear of the column.
In stages I changed a few other things, moved the Z feedscrew nearer the dovetail, fitted a ex computer tape motor, (later a1Kw servomotor), polyvee belt, converted spindle to a proper quill. It not in use at the minute because I have another mill with longer table travel but l miss its belt drive quietness and smoothness.
MW10/06/2017 10:51:25
2052 forum posts
56 photos
Posted by Neil Wyatt on 09/06/2017 14:30:17:
Michael W
Well I guess I better get to it then !yes
Michael W
Matthew Corner29/08/2023 15:38:33
3 forum posts
looks like it would chew some metal!
