Drill bit accuracy
David Cambridge | 03/06/2017 16:28:06 |
252 forum posts 68 photos | For a while I’ve been buying my drill bits from Warco, and I found them to produce a hole size that was pretty much spot on. My definition of being spot on being a nice sliding fit with ground silver steel of the same diameter. Drill bits I’ve bought from RDG tools, Amadeal, and Arc Euro trade were all just as good. I then switched to one of the bigger ebay suppliers and bought sets of ‘precision ground TIN’ and results are all over the place. Price wise, and in packs of 10 they were maybe 2/3 the price of the suppliers mentioned above. Over a cross section of sizes, A 4mm ebay drill is producing a hole size of 4.32mm, a 6 mm drill 5.95mm, and 8mm drills were banana shaped.
I’m also curios to know what people deem acceptable hole size accuracy ? The results are the same for drilling in either the mill or the lathe, with different chucks used for both, across a good sample of the packs of 10 drill bits, and results measured in aluminum, brass, and steel. Returning to the above ‘engineering’ suppliers with my old drill bits produces the same excellent results, so nothing has gone wrong in my machines. David
David Cambridge | 03/06/2017 16:52:34 |
252 forum posts 68 photos | Thinking about it, I should probably define what I mean by acceptable. For the sake of this discussion, let’s say it means an accuracy to keep 80% of the people on this forum happy when considered against a set of drills for general model engineering. David |
Howard Lewis | 03/06/2017 16:54:43 |
7227 forum posts 21 photos | If the point of the drill is not on the centreline, it will cut oversize. The longer cutting edge will rotate about the point and result in an oversize hole. If you are sharpening drills, yourself, you need to be careful of this. Not everything cheap is good value. Howard |
Nick_G | 03/06/2017 16:56:47 |
![]() 1808 forum posts 744 photos | . I usually buy Dormer drills and search for them. I have however had an 11.5mm one supplied that was no more a Dormer brand drill than I am Neil Armstrong.! - It even had Dormer printed on it but at a low quality. I showed it to a pro machinist mate of mine who just laughed at the ground cutting edges. I have never used that particular supplier again. Like many things there are fakes out there. One of the biggest brands being faked is Scandisk memory cards to such an extent that many have stopped buying that brand. Even major retailers have been duped and unknowingly sold them on thinking they were genuine. Nick |
mechman48 | 03/06/2017 19:10:27 |
![]() 2947 forum posts 468 photos | Hi David |
Clive Brown 1 | 03/06/2017 19:28:15 |
1050 forum posts 56 photos | My elderly "Dormer Twist Drill and Reamer Information Handbook" lists diametral tolerances according to BSS. All tolerances are +.0000. Minus tolerances vary from - .014 mm for drills up to 3 mm. dia. to -.054 mm for drills between 80 to 120 mm. dia. A 10mm drill for example would be +0, -.027. Off-centre grinding would change this of course. All reamers are plus tolerances Edited By Clive Brown 1 on 03/06/2017 19:31:31 Edited By Clive Brown 1 on 03/06/2017 19:33:26 |
Nick Hulme | 04/06/2017 12:06:23 |
750 forum posts 37 photos | I buy as much of my tooling as possible from my local engineering tool suppliers in Sheffield, they supply industrial customers so even budget priced offerings have been tried out and found to be acceptable for production work. I mainly use Dormer, Guhring and other major brands, I haven't seen the need to go cheap on drill bits yet as I suspect they don't work out cheaper in the long term. |
