Frog 500 Glow motor
Con rod dimensions
Graham Williams 518/04/2017 14:56:28
98 forum posts
9 photos
Picked up a couple of model aircraft engines from a flea market yesterday, an Elfin 249PB, beam mount, and a Frog 500 glow-motor, at a good price, wasn't expecting much. Elfin is locked up so soaking away in solvent. Frog came apart OK but big end of con-rod badly oval so will need to make another, otherwise it looks like it might be a runner, screw heads and fins etc. not butchered. Can anyone help with accurate hole centres for the con-rod please. Quite a bit of info on the web but not that dimension. Cheers Graham W.
Speedy Builder518/04/2017 16:17:15
2878 forum posts
248 photos
Cross section x stroke = cc, so
stroke = cc/area of the piston
Hacksaw18/04/2017 16:19:15
474 forum posts
202 photos
Sadly only have a 349 diesel...but I saved it from my mates skip ! surprise
He has 2 petrol Mighty Midget ? engines of his late fathers he would part with.... reconditioned , with invoices from a long time ago , and never used....
SteveW18/04/2017 18:31:28
140 forum posts
11 photos
Stroke not same as con rod length. You do need a rod or estimate from the old one?
Graham Williams 518/04/2017 18:58:39
98 forum posts
9 photos
Possibly 1 3/8 inch but wanted to be sure before I started on a replacement.
TobaccoBurner19/04/2017 01:22:17
30 forum posts
With some measurements from the engine and the timing info from here (page 121):-
http://rclibrary.co.uk/files_titles/1561/Model_Aircraft_1950_05.pdf
it should be possible to compute (or measure from a cad drawing) the required length.
Am part way through a similar exercise with a DC Spitfire. Having settled on a dimension I ran an animation in Fusion360 to check if it made sense. Now just need do final assembly, find a prop and then we see whether I got it right.
D Hanna19/04/2017 10:20:29
45 forum posts
6 photos
Have you got a dimension yet? If not I han pull one apart and measure for you.
Graham Williams 519/04/2017 10:28:55
98 forum posts
9 photos
No, haven't got a dimension yet, that's a very kind offer, would be greatly obliged. Cheers Will
not done it yet19/04/2017 11:05:30
7517 forum posts
20 photos
All you need to know is the protrusion (or not) of the piston and the stroke. The rest is then easily calculated from the parts in hand.
I read the interesting history, by Adrian Duncan, of that engine. i see there are copies, spark ignition and glow plug variants, and the later replicas had slightly different dimensions (metricated). Piston to head clearance may be the most important tolerance.
If a petrol variant (these were convertible to glow plug) it would appear you may have a quite rare and more valuable version.
D Hanna19/04/2017 11:18:49
45 forum posts
6 photos
The one I have has a centre distance measured over a big end pin of 0.2187 and little end of 0.1875 = 1.395" . Maybe a bit of ovality but should get you somewhere near the mark. You can have this one unless you want to make one for the fun of it! Just pm your address if you do want it.
DH
OZ
Graham Williams 519/04/2017 11:57:51
98 forum posts
9 photos
PM's sent guys
D Hanna19/04/2017 12:33:16
45 forum posts
6 photos
Posted by Graham Williams 5 on 19/04/2017 11:57:51:
PM's sent guys
Returned pm. In the mail tomorrow for youwink
Graham Williams 516/05/2017 12:28:55
98 forum posts
9 photos
Just sat in the workshop looking at the Frog 500 I picked up recently, holding another con rod sent all the way from OZ. I can only say that the generosity of people using this forum, either with advice, or in this case providing a scarce part is pretty overwhelming. smiley. Thanks to everyone but particularly Dallas.yes
