Martin Cargill | 15/04/2017 16:52:48 |
203 forum posts | Wanting a bigger, more robust pillar drill I purchased an Arboga E830. I looked at it thinking that, as the motor was mounted on the top of the drill, it would be easy to convert from three to single phase to suit my workshop electrics. Sadly this was not to be the case as when I removed the motor I found it had a shaft about 10" long with two gears on the end. Not to be put off by this I ended up lengthening the shaft on the other end of the motor and added a belt drive with a single phase motor piggy backed on the side of the main motor. I now have a serious 2.5 HP drill (with power feed!), an MT4 spindle and speeds from 80 to 890 rpm. The problem that I have is finding a manual for the machine, I can buy one from Lathes.co.uk but they want £39 - this is more than a quarter of what I paid for the machine. Does anyone have a copy of the manual for this machine?
Martin |
Thor 🇳🇴 | 15/04/2017 17:12:45 |
![]() 1766 forum posts 46 photos | Hi Martin, Congratulations, Sweden made many good machine tools. Found this parts diagram, may be that can be of some help:
Thor |
Martin Cargill | 15/04/2017 17:33:10 |
203 forum posts |
Thor, Many thanks for your prompt response. Unfortunately the link you have provided is for the ER830, this is the radial arm version of the drill that I have and many of the features are different because the controls have all been moved to the left hand side of the drill (I had already found this drawing in my search). Thank you for trying. Martin
Benny Avelin | 15/04/2017 20:15:07 |
80 forum posts 86 photos | How about sending the service department an email at arbogamachinery if they can provide a parts diagram? |
