Hello
mark hopley | 29/03/2017 01:22:33 |
3 forum posts | Hi guys I'd like to say hi. I'm in Bridgewater Somerset I'm looking to kit out my shop/garage To do some machining Turning drilling milling I've been restoring old vw s for years but although I get stuff machined it's getting costly. I actually started life as a turner fitter. Hi using wards. Deane Smith Grace. Big Elliot radials an so on. I've been a maintenance fitter for years as well as a car and bike restorer. I'm looking for a mill drill any ideas. Maybe a use full lathe for machining brake discs and drums Facing flywheel. I'd love a Myford super 7 but think it 'll be too small Or a boxford but again probably on the small side. I haven't got a massive budget and needs to be ideally single phase. Any hell would be welcome Cheers mark |
Neil Wyatt | 29/03/2017 09:11:03 |
![]() 19226 forum posts 749 photos 86 articles | Hello Mark, Welcome to the forum. I'm sure you will get lots of suggestions... Neil |
Chris Evans 6 | 29/03/2017 09:20:31 |
![]() 2156 forum posts | Welcome Mark, for you kind of work (I am a bike restorer) the Myford is to small and they also fetch good money. Don't let three phase put you off I run my Bridgeport mill off a cheap (£90) Chinese VFD inverter. When you do buy a lathe look at the size of the spindle bore some are very small. You will need a lathe with a decent "swing" to get a car flywheel on. |
ega | 29/03/2017 09:38:17 |
2805 forum posts 219 photos | mark hopley: You might consider a Willson slant bed lathe which will comfortably swing 420mm. They come up on eBay from time to time and seem to be good value. Re-motoring to single phase would be a straightforward alternative to VFD. |
mark hopley | 29/03/2017 10:48:49 |
3 forum posts | Hi guys thanks yes the bigger swing the better. Decent gap bed of some description. Yes we have loads of decent inverters in work. Allen Bradley and Siemens lots of spares lol. They chucked a load a while back. So yes I need to get my head round wirring one. I do like the idea of having it in high and a speed control knob. My other issue is my lane is narrow and basically in level and dirt about a 100 ft long so I have to keep the weight down To get it in as it's tight get s transit up but turning s an issue. |
John Flack | 29/03/2017 11:41:52 |
171 forum posts | I wonder if I might as a question on this post I have no greater knowledge beyond inserting a 3 pin plug into a socket. Talk of single , three phase and other technical stuff is hard going to paracetamol level. Recently our heating engineer, suggested that we switch to an electrical boiler, and produced leaflets etc. He then sent round his electrical specialist who calculated the floor area and said oh no you can't you will need two linked boilers which is beyond the local overhead cable capacity. This was not something I was even aware of. In simple terms how does one establish what equipment can be used in which location . Who should one approach to avoid plunging the district into darkness, is this a rural problem, is a SIMPLE calc available before purchasing larger upgrades of equipment. This info may of help to those intending heavy metal removal Sorry if the question is "Simple" to some. (We ended up staying with oil)
John Flack | 29/03/2017 11:44:13 |
Howard Lewis | 30/03/2017 16:22:13 |
7227 forum posts 21 photos | A secondhand Warco BH600, Chester Craftsman, or Engineers ToolRoom BL12-24 (clones other than paint scheme) will swing up to 18 inches in the gap, as will their successors, and ex Tech College, or Industry lathes. The problems with ex Industry machines are that they will have worked hard for their living, and are likely to be 3 Phase, and so will need a change of motor to work in a domestic environment off a 13 Amp socket. Ex Tech College machines will have done little work, but probably been abused, by things like running the toolpost into the chuck and so on. Once you have a lathe, (and hopefully, a Milling machine) the world will almost be your oyster, with a huge range of jobs now possible. ENJOY! Howard |
Chris Evans 6 | 30/03/2017 19:25:13 |
![]() 2156 forum posts | Remember Mark once you get a lathe you also get 100 friends. |
mark hopley | 30/03/2017 19:35:20 |
3 forum posts | Lol thanks guys for your advice Well I've managed to secure a Dore Westbury mill drill, well happy Just a decent lathe with a good swing. Cheers mark
