Adrian 2 | 19/02/2017 08:39:15 |
104 forum posts 19 photos | Morning all, Does anyone have experience of removing the right hand leadscrew bracket on the Myford lathe ? In addition to the two cap head screws there are two dowels tapped to aid extraction . Not sure which thread as they are damaged. With the screws removed the bracket is still firmly held in place by the dowels. I'm thinking a simple extractor to draw the dowels and bracket off as a unit. Any advice appreciated thank you. Adrian. |
Lambton | 19/02/2017 08:54:52 |
![]() 694 forum posts 2 photos | Adrian, Looking at the parts list in the Myford handbook the dowels are standard plain ones. They are, like all good dowels, a very close fit in their holes and are therefore difficult to remove. Try gently prising the bracket off using the "two screwdrivers" technique. Go gently a little at a time and you should have no trouble. Eric |
John Haine | 19/02/2017 09:10:34 |
5563 forum posts 322 photos | The dowels are tapped 4 BA. You need a few inches of 4 BA studding, a BMW weight say 1" diameter and a couple of inches long drilled to clear, and a 4 BA nut. Nuy on one end of stub, thread through weight, screw other end into dowel, then slide weight smartly against nut a few times to extract dowel. |
Adrian 2 | 19/02/2017 09:50:16 |
104 forum posts 19 photos | Thank you for your replies. The slide hammer idea sounds good . I will do it that way. Adrian. |
Lambton | 19/02/2017 12:06:03 |
![]() 694 forum posts 2 photos | Just been to look at my lathe and I confirm that the dowels are tapped. Very thoughtful of Nottingham Myford. |
John Purdy | 19/02/2017 18:18:50 |
![]() 431 forum posts 252 photos | I have removed the bracket a number of times by screwing in a 1" 4BA screw and giving the head a good tug with the fingers. Mine are a snug but sliding fit in both the bed and the bracket. John |
Adrian 2 | 19/02/2017 18:59:52 |
104 forum posts 19 photos | That's encouraging John, it may not be as difficult as I at first thought. Adrian. |
