Westinghouse pump in 5" gauge
Information required
John Billard 101/02/2017 17:42:31
111 forum posts
I am building a Gresley rebuild of a Great Eastern Super Claud of which a Westinghouse pump is an essential feature that I would like to include but as a boiler feed. I have seen this done. Roy Amsbury refers to it in a past Model Engineer but details are sketchy. Don Young includes it in his O2 drawings, but as earlier LBSC versions also show, this is a little out of scale. Any information or thoughts would be greatly appreciated.
Kind regards, John Billard
Granville Askham01/02/2017 19:38:02
6 forum posts
Hi John, I have details and, I think lots of pic of Westinghouse air pumps. I built a 3.5" narrow gauge 'Russell' with the air pump on the front. a bit bigger than you need, my scale is about 1.75" to a foot. PM me and I will see what I can find.
GeorgeG
Simon Collier01/02/2017 20:28:27
525 forum posts
65 photos
I have one of these on my Simplex:
http://www.hugin.com.au/modelrail/single1inch.htm
John Billard 101/02/2017 22:41:33
111 forum posts
Thanks, GeorgeG, I have PMd you.
John Billard 101/02/2017 22:42:57
111 forum posts
Thanks Simon, I will investigate! Do you use it as boiler feed?
Kind regards
julian atkins01/02/2017 23:55:26
1285 forum posts
353 photos
Hi John,
The Don Young 'Fishbourne' IOW O2 5"g design doesnt work!
There is little information on a scale 5"g design single acting pump. I have seen a number of LBSC type pumps work on 5"g locos of single cylinder type, and driven a few with this type, but the rocker arm to avoid the crossed ports is a serious departure from fullsize. To avoid the rocker arm you need crossed ports which very considerably complicates making the steam chest.
In 7.25"g this isnt a problem, but in 5"g it is very very tricky to replicate a scale Westinghouse pump.
Cheers,
Julian
Edited By julian atkins on 01/02/2017 23:56:47
Simon Collier02/02/2017 10:21:43
525 forum posts
65 photos
Yes, as a boiler feed pump. The engine has this and one excellent injector, also made by Warwick Sandberg. I almost always use only the injector but the pump does work well.
John Billard 102/02/2017 10:25:23
111 forum posts
Thanks Julian. I note that the most exquisite 5" g models usually have a dummy pump and this supports what you say. However I have seen it done.
Kind regards, John
Bob Youldon02/02/2017 12:16:45
183 forum posts
20 photos
Good morning John,
I cannot remember seeing any article in the model press giving details for the construction of a"Westinghouse" pump to suit 5" gauge, as you say Roy Amsbury gave some brief details in the Model Engineer many years ago but I've yet to see one in operation. Don Young's pump for his O2 is based on an early pre war LBSC design being reliant on an over center spring arrangement and probably a bit iffy in it's performance, I understand Gerry Tull built a working pump to his own design for his O2 although I always thought it was too small for the O2. Don did describe pumps for his Lucky Seven design and his Terrier "Newport" these being based on an American design by Moodie E Braun Jnr in the American publication Modeltec November 1984, subsequently the design was revised in Modeltec in September 1985 by Bill Esty. Many years ago I built a 5" gauge A1X Terrier and I experimented with a "Westinghouse" steam pump, i had several goes at it finally utlising a small piston valve in the pump head operated by the trip rod and a slide valve built into the rear of the steam cylinder, In that size the main problem was one of condensation, but when kept hot would work quite well; I had it with me one time visiting the late Lionel Woodhead who at that time had just finished a Brighton B4, well that was the last I saw of it, it still resides on the side of the B4 firebox.
Bob
Another JohnS02/02/2017 13:30:34
842 forum posts
56 photos
John;
To add to what is written above; I have a 3-1/2" gauge locomotive with a single cylinder "water pump" where the cross compound pump is on the original. It's behind a shroud, so is partially hidden.
It sometimes works, sometimes not.
Have purchased two 3" Southworth pump kits, one to replace this pump with something (hopefully) more reliable.
One could adapt the design/parts to better resemble a single cylinder Westinghouse air compressor - maybe food for thought?
Time will tell as to whether this replacement works better than the original on my locomotive - JohnS.
John Billard 102/02/2017 21:51:59
111 forum posts
Thank you for the ideas so far which are encouraging.
For those who have access The Roy Amsbury drawing is in ME Vol 143, No 3564 p 754 (1977). He made it work but there are few dimensions shown. Perhaps with some persistence this could be pursued.
A visitor came to the Reading track some years ago with a lovely 5" LT&SR 4-4-2 tank with the pump filling the boiler very realistically. Unfortunately I don't have his details.
Kind regards
Another JohnS03/02/2017 02:18:48
842 forum posts
56 photos
John;
"over here" (North America) there are lots of smaller locomotives with dual-cylinder water pumps. Lots of locomotives had them (at least here in Canada). Cross-compound air compressor(s) and sometimes a water pump.
A fellow Model Engineer Bill Shields has drawings on his web site:
http://http://mehrs.com/ (link) **LINK**
I don't know of a single cylinder or two cylinder pump is what you are looking for, so "just for your info"
Brian Baker 103/02/2017 08:00:54
229 forum posts
40 photos
Greetings, A long time ago, I built a Great Eastern Railway S56 Class "Buckjumper" in 5 inch gauge, which had a working Westinghouse pump, which was based on the Roy Amsbury design.
Roy was very helpful with details, and the pump worked fine, but tended to run a little fast.
I have to say that I think it used more steam than it put water in the boiler.
John Billard 103/02/2017 10:50:17
111 forum posts
Thank you John, I will follow that up. Brian, did you retain the advice from Roy? I appreciate the time lapse. That is a lovely model though. Congratulations.
Best wishes
Brian Baker 103/02/2017 12:19:23
229 forum posts
40 photos
Hi John, I finished it in 1986.
If I kept the details, it would be in the archives & need looking out.
I will have a look later today.
regards
BB
John Billard 103/02/2017 12:39:33
111 forum posts
That's very kind of you, Brian
julian atkins05/02/2017 22:32:33
1285 forum posts
353 photos
Hi John,
You are very privileged to have the likes of Bob and Brian contribute to this discussion as they have both made working examples.
I knew Gerry Tull quite well and drove his award winning IOW O2 'Totland' but never saw the pump work. The 2 injectors supplied the boiler.
Cheers,
Julian
Brian Baker 106/02/2017 17:42:46
229 forum posts
40 photos
tull1 001.jpgtull2 001.jpgHi John, sorry to take so long, but I had filed his letter in the wrong place 32 years ago, and it took time to find it.
It looks like his typewriter ribbon was on its way out, but I hope you can read this scan.
If not PM me & I will email it to you.
Not as much help as I remembered.
for your info, I have built 6 various pumps of this type, and the best operating one was based on a design in "live steam", I will try to find the date.
John Billard 106/02/2017 19:31:11
111 forum posts
Thank you very much Brian for taking the time and trouble in looking out this information. I can read it. Everything is valuable. It says a great deal for this forum and its contributors with the responses I have received and I feel very encouraged, and as you say, Julian, privileged.
Best wishes
John Billard
julian atkins11/02/2017 23:27:49
1285 forum posts
353 photos
Hi John,
You need to take a pinch of salt with some of what Gerry Tull wrote.
I never saw that pump working though I saw the loco running lots of times, and drove his gold medal winning 5"g IOW O2 based on Don Young's 'Fishbourne' design.
Gerry always said his whistle was 'special' for the O2. I never heard that either! He described in LLAS how he had researched how to make the perfect whistle. (He also described in LLAS how he made the pump).
Anyway jump on 30 or so years and Gerry's IOW O2 is now owned by a guy in the Isle of Man. At my request he very kindly took the whistle off the loco and measured it up and sent me pics. It is just a bog standard whistle - nothing special about it at all!
Bob has very kindly sent me the drawings of his own Westinghouse pump example. I would be very interested to know from Brian how he managed his own examples in 5"g.
Gerry was a wonderful guy and I am sure is sadly missed by many friends. I have quite a considerable correspondence with him, but unlike Brian my letters from Gerry have a printed letterhead with a printed picture of his O2 above!
The Southworth smallest pump is far too big for a standard gauge 5"g loco for scale size of a Westinghouse pump.
Cheers,
Julian
