Recycling lathe castings
PaulR31/01/2017 14:48:56
123 forum posts
21 photos
I have a couple of top/cross-slide castings from a Chinese lathe (not sure what model) - are they likely to be any good for chopping up and using as raw material?
Bazyle31/01/2017 18:05:11
6956 forum posts
229 photos
Are you implying they are just loose bits rather than going together as a whole? The iron must be reasonably machineable to have got that far. But even if it is only a part with the dovetail already made it could be more use to make the other half than to cut it up.
Plenty of uses for a lonely top slide in other machines like a grinder.
Brian Oldford31/01/2017 19:48:59
686 forum posts
18 photos
Posted by Bazyle on 31/01/2017 18:05:11:
Even the basis for a vertical slide.
PaulR31/01/2017 21:41:34
123 forum posts
21 photos
I haven't looked at them for a while, but I'm pretty sure one or both are the dovetailed parts but from different machines (I think!). I'll dig them out tomorrow and take a look. I don't need them as parts for other machines which is why I thought I could cut them up when required, cast iron is soooo expensive these days.
peak431/01/2017 21:44:27
2207 forum posts
210 photos
Seems a shame to chop them up; another use would be for a lever operated slotting attachment for internal keyways etc.
I'm actually looking for one to do that job myself.
All The Best
Bill
Brian Oldford31/01/2017 21:49:57
686 forum posts
18 photos
Posted by peak4 on 31/01/2017 21:44:27:
All The Best
Bill
If you find two let me know.
peak401/02/2017 00:36:00
2207 forum posts
210 photos
Posted by Brian Oldford on 31/01/2017 21:49:57:
All The Best
Bill
I did actually lash something up using my Myford top slide, by removing the lead screw and end plate.
The latter being replaced with a bit of angle iron and a linkage to a lever , whichpivoted on a piece of round bar bolted to one of the Tee slots on the cross slide.
I then used this to make splined shafts for the Ducati brake linkage out of Stainless bar when i was restoring it.
Indexing was done by a gear train off the headstock spindle.
Also used a similar arrangement for cutting a keyway in a pulley.
PaulR01/02/2017 21:37:47
123 forum posts
21 photos
Here are the two bits but I'm not sure if the rusty fellow is actually a machine part - someone has filed a little bit off a corner, I'm guessing to see whether it's cast iron or steel. The one with the bit of brass attached is for a Clarke machine, it was sent to me in error when I ordered a mini-lathe part and they told me to keep it to avoid the cost of return post!
Tony Willis 113/02/2017 16:43:02
3 forum posts
You could turn the left one into a nice machine vice.
Martin King 213/02/2017 17:46:35
1129 forum posts
Hi,
Got this small dovetaily thingy in one of my crates, might do for someone? PM if of interest.
Martin
PaulR13/02/2017 20:30:48
123 forum posts
21 photos
Posted by Tony Willis 1 on 13/02/2017 16:43:02:
That would be nice but I don't have the equipment to make a mating part - can't see me milling that in the vertical slide laugh
