Dougie Swan | 20/01/2017 06:42:27 |
269 forum posts 73 photos | Hi Can anyone tell me if there is a chemical that will etch aluminium like ferric chloride works for brass? Thanks Dougie |
Speedy Builder5 | 20/01/2017 07:08:16 |
2878 forum posts 248 photos | Caustic soda ? |
John Haine | 20/01/2017 07:13:38 |
5563 forum posts 322 photos | Caustic soda certainly but very aggressive! I believe that sodium carbonate, a/k/a washing soda, works well and will be safer. Milk bottle tops in washing soda was a way to make hydrogen gas at home if you didn't want to use zinc and hydrochloric acid. Note, etching Ali with an alkali gives off inflammable hydrogen so good ventilation and no naked flames indicated. A bit of searching throws up this link that confirms a pretty vigorous reaction between hot NaCO3 solution and aluminium foil evolving bubbles of hydrogen gas. https://m.youtube.com/watch?v=ggPWdwcsyqM Edited By John Haine on 20/01/2017 07:24:43 |
David Cambridge | 22/01/2017 07:36:16 |
252 forum posts 68 photos | Have you considered electrolysis ? I’ve been meaning to try it with salt and electricity, but I still need to do a bit of research before I try it (just in case it yields anything nasty!) David |
John Haine | 22/01/2017 09:43:00 |
5563 forum posts 322 photos | No need for electrolysis! Actually printmakers use aluminium for etching plates as an alternative to zinc, using a mixture of copper sulphate and common salt, which has the advantage that it also etches zinc so you only need one solution. I suspect that it is also much more controllable than sodium carbonate (judging by that video I linked to), which is important when making an etching plate. |
Neil Wyatt | 22/01/2017 09:44:47 |
![]() 19226 forum posts 749 photos 86 articles | Posted by David Cambridge on 22/01/2017 07:36:16:
(just in case it yields anything nasty!) Hydrogen and Oxygen in an exact 2:1 ratio ... 'keep away from naked flame'... Neil |
Michael Gilligan | 22/01/2017 09:53:04 |
![]() 23121 forum posts 1360 photos | Posted by John Haine on 22/01/2017 09:43:00:
No need for electrolysis! Actually printmakers use aluminium for etching plates as an alternative to zinc, using a mixture of copper sulphate and common salt, which has the advantage that it also etches zinc so you only need one solution. . . Thanks for that, John My day isn't wasted ... I've learned something already. MichaelG. |
Dougie Swan | 22/01/2017 10:02:33 |
269 forum posts 73 photos | Thanks for the replies I will have a go with a few tests later Dougie |
Neil Wyatt | 22/01/2017 10:18:54 |
![]() 19226 forum posts 749 photos 86 articles | If the results are worth reporting on, a short write up for MEW would be useful Neil |
David Cambridge | 22/01/2017 12:01:29 |
252 forum posts 68 photos | 'Hydrogen and Oxygen in an exact 2:1 ratio ... 'keep away from naked flame'...' At the risk of being a pedant, it’s hydrogen and chlorine – so keep away from naked flames and naked lungs (if you want to use them afterwards ). David
John Haine | 22/01/2017 12:25:16 |
5563 forum posts 322 photos | Using sodium carbonate it just liberates hydrogen, certainly not chlorine. The link I posted earlier was rather general, the one I should have posted is here. He doesn't mention chlorine as a hazard. |
vintagengineer | 22/01/2017 13:09:28 |
![]() 469 forum posts 6 photos | Ferric Chloride will etch aluminium quite nicely. We used to use it for making aluminium flexible pcbs. It will need agitating as the spent etch will sit on the surface and slow down the process. A warning, keep low grade gold jewellery away from the solution. It used to be quite embarrassing when we had to explain to young ladies that their engagement rings had fallen apart due to very little little gold and lots of copper in the rings! Edited By vintagengineer on 22/01/2017 13:16:45 |
Neil Wyatt | 22/01/2017 14:20:00 |
![]() 19226 forum posts 749 photos 86 articles | Posted by David Cambridge on 22/01/2017 12:01:29:
Ah I hadn't noticed the electrolyte had changed from sodium carbonate to salt! In that case keep away from direct sunlight too.. |
duncan webster | 22/01/2017 17:27:04 |
5307 forum posts 83 photos | Won't the chlorine dissolve in the water? If so you'll get hypochlorous and hydrochloric acid rather than gaseous chlorine. Still better to stick to carbonate. |
