Neil Wyatt | 04/01/2017 18:01:13 |
![]() 19226 forum posts 749 photos 86 articles | Seeking 3/8" O/D brass tube with a 1/16" (or 0.065" The usual suspects only seem to stock 0.035" wall tube. Sadly google gets confused by the fractions as most sites stock 3/8" AND 1/4" OD tube, but with thin walls. I found one source in the US! There must be a UK source as I have a small piece in my workshop. Ideally as a cheap (it doesn't need to be super long lasting) alternative to oilite bushes. Neil |
Bazyle | 04/01/2017 18:25:06 |
![]() 6956 forum posts 229 photos | There are tubes designed to fit into one another - probably what you were finding. If you soldered one inside another using whitemetal if it wore through the bearing properties would improve. |
Phil P | 04/01/2017 18:29:20 |
851 forum posts 206 photos | Neil Macc Models on here have it listed. https://maccmodels.co.uk/materials-metal/brass-sections/brass-tube/16g-brass-tube/3-8-x-16g-brass-tube.html Phil |
Neil Wyatt | 04/01/2017 19:25:30 |
![]() 19226 forum posts 749 photos 86 articles | Posted by Phil P on 04/01/2017 18:29:20:
Neil Macc Models on here have it listed. https://maccmodels.co.uk/materials-metal/brass-sections/brass-tube/16g-brass-tube/3-8-x-16g-brass-tube.html Phil Excellent, thanks Phil Neil |
Michael Gilligan | 04/01/2017 19:34:45 |
![]() 23121 forum posts 1360 photos | Posted by Neil Wyatt on 04/01/2017 18:01:13:
Seeking 3/8" O/D brass tube with a 1/16" (or 0.065" . Might get better results if you specify wall thickness MichaelG. |
