Andrew Tinsley | 01/01/2017 23:38:47 |
1817 forum posts 2 photos | I have just finished setting up the headstock of my ML7. The shims that Myford used are laminated shims. Each shim 2 thou thick. This is such a convenient way of using shims that I would like to source some of it for future use. Simply cut the shim to shape and peel off successive layers until the thickness is correct. Beats having to cut shims until all is correct. Is this material made anymore? Thanks, Andrew
Michael Gilligan | 01/01/2017 23:43:31 |
![]() 23121 forum posts 1360 photos | Short answer = Yes Longer answer = Google search for Laminated Shim Stock MichaelG. |
Nicholas Farr | 01/01/2017 23:48:12 |
![]() 3988 forum posts 1799 photos | Hi Andrew, looks like these people do it **LINK** Regards Nick. Exactly as MichaelG said. Edited By Nicholas Farr on 01/01/2017 23:50:02 |
Andrew Tinsley | 01/01/2017 23:49:05 |
1817 forum posts 2 photos | Thanks Michael, I did a search and nothing came up that was relevant. I will use Google this time! Andrew. |
Andrew Tinsley | 01/01/2017 23:56:58 |
1817 forum posts 2 photos | OK Google lists loads of American manufacturers and stockists and you can get the material on Ebay from the US at prices around £60 plus not inconsiderable postage! Anyone know of a UK stockist that would supply small quantities? Andrew. |
not done it yet | 02/01/2017 00:32:23 |
7517 forum posts 20 photos | Try adding 'UK' after your search criteria on 'goggle'. It will then prioritise (mostly) UK hits, hopefully. |
roy entwistle | 02/01/2017 10:00:33 |
1716 forum posts | The link that Nicholas Farr gave is in Worcester Roy ( Happy new year to all ) |
Andrew Tinsley | 02/01/2017 16:33:16 |
1817 forum posts 2 photos | Hello again, My post crossed with the one from Nick, so apologies for my unintended snub. I will give them a call and see if they are willing to sell small quantities. Most companies don't want to know about small quantity enquires for a model engineer. However I might strike lucky, well worth trying. Thanks for the lead, I will come back and let you know if they are willing to sell! Happy New Year to all, Andrew. |
MalcB | 02/01/2017 16:44:56 |
257 forum posts 35 photos | Boneham and Turner do Laminated shim. Think they still do both brass and steel. http://www.boneham.co.uk/shop/product/shim
MalcB | 02/01/2017 16:46:00 |
257 forum posts 35 photos | Oops!
Edited By MalcB on 02/01/2017 16:46:31 |
Martin Connelly | 02/01/2017 18:56:51 |
![]() 2549 forum posts 235 photos | Pruftechnik Lamibloc, no idea of cost. Martin |
MW | 02/01/2017 19:02:46 |
![]() 2052 forum posts 56 photos | This may be an inopportune place to post but is there anywhere you can still get Tinplate for soldering? (apologies to Andrew for the highjack) Michael W Edited By Michael-w on 02/01/2017 19:04:20 |
John Hinkley | 02/01/2017 19:11:59 |
![]() 1545 forum posts 484 photos | Michael W, modelshop.co.uk have it on their web site. Hi-jack brought to a successful conclusion. John |
MW | 02/01/2017 19:14:42 |
![]() 2052 forum posts 56 photos | Posted by John Hinkley on 02/01/2017 19:11:59:
Michael W, modelshop.co.uk have it on their web site. Hi-jack brought to a successful conclusion. John Thanks John, Much appreciated, let the normal discussion continue Michael W |
Michael Gilligan | 02/01/2017 19:16:23 |
![]() 23121 forum posts 1360 photos | Posted by Michael-w on 02/01/2017 19:02:46:
This may be an inopportune place to post but is there anywhere you can still get Tinplate for soldering? . These guys seem to have plenty: **LINK** http://www.bellingham-steel.co.uk/ Not sure if they would supply small quantities though MichaelG. . Edit: sorry, discussion closed whilst I was posting. Edited By Michael Gilligan on 02/01/2017 19:17:22 |
MW | 02/01/2017 19:31:06 |
![]() 2052 forum posts 56 photos | Posted by Michael Gilligan on 02/01/2017 19:16:23:
This may be an inopportune place to post but is there anywhere you can still get Tinplate for soldering? . These guys seem to have plenty: **LINK** http://www.bellingham-steel.co.uk/ Not sure if they would supply small quantities though MichaelG. . Edit: sorry, discussion closed whilst I was posting. Edited By Michael Gilligan on 02/01/2017 19:17:22 Thanks for the input, Michael, it looks like they've got more than i'll ever need! :P Michael W |
