Clock Wheel
Mark Bus29/12/2016 16:56:32
50 forum posts
21 photos
Hi,
I cut the center wheel on the clock I'm currently building and one of the teeth is narrower than the rest ; something must have slipped. Its 1 Mod. , the teeth are about 61 thou. except the narrow tooth which is about 46 thou. Is this going to cause any problems with the operation of the clock? The perfectionist in me is screaming in agony while I scourge myself with barbed wire for making the error, but the rational man thinks that it won't matter.
Thanks,
Mark
Andrew Johnston29/12/2016 17:03:10
7061 forum posts
719 photos
If something slipped you'd expect one tooth to be narrower and one tooth to be wider. If one is too narrow and all the others are equal then there must be something wrong in the orginal calculations. I've no idea if it'll run, but personally I'd make it again.
John Haine29/12/2016 17:09:21
5563 forum posts
322 photos
I had a similar issue making a ratchet wheel. It turned out that the blank had not been firmly enough clamped to the mandrel, so every time a tooth was cut it slipped slightly. Overall it lost more than a tooth but every tooth looked OK. Next time I put more wellie on the clamp nut and all was OK. You might also check that you have the expected number of teeth...?
Bob Stevenson29/12/2016 17:15:17
579 forum posts
7 photos
Welcome to 'wheelmakers angst'....
There's good and bad news;...it'll probably work,...but you will always 'KNOW' every time you look at the clock!
If you have already crossed out the spokes etc then keep going...if it's just the blank with teeth then do it again....clockmakers can prefer one or the other methods for various reasons .
john carruthers31/12/2016 08:50:17
617 forum posts
180 photos
can you scarf and solder in a new tooth?
Michael Gilligan31/12/2016 09:12:30
23121 forum posts
1360 photos
Posted by john carruthers on 31/12/2016 08:50:17:
John,
I would be interested to understand how you see this working:
I have inserted teeth to replaced damaged ones, but I honestly can't see how one under-size tooth could be successfully replaced.
Mark wrote: Its 1 Mod. , the teeth are about 61 thou. except the narrow tooth which is about 46 thou.
john carruthers31/12/2016 09:26:55
617 forum posts
180 photos
I am assuming there are comensurate wider spaces either side, or on one side, of the narrow tooth? if not then it's a non starter.
Michael Gilligan31/12/2016 09:37:15
23121 forum posts
1360 photos
Posted by john carruthers on 31/12/2016 09:26:55:
Thanks, John ... understood.
I guess we need a photo to clarify.
[Mark] Could you put the wheel on a flatbed scanner, and post an image, please?
Neil Wyatt31/12/2016 11:08:27
19226 forum posts
749 photos
86 articles
I've had this happen if the wheel isn't held 100% securely. What happens (I hypothesise) is that the vibration from cutting is slightly imbalanced and the wheel creeps imperceptibly and it's only at the final cut taht the error is visible.
Mark Bus31/12/2016 19:40:53
50 forum posts
21 photos
Hi,
The wheel has the correct number of teeth. The spaces on each side of the narrow tooth are the same. Tooth tip to tooth tip distance is equal. The mistake occurred when i was cutting the first two teeth when I was going back and forth to get the right depth of cut. It dawned on me to mount it on my depthing tool to see if it would work with it's respective lantern pinion. I set it at the correct theoretical spacing. Well , I did that and I didn't notice any problems. I got to thinking that if it was the opposite problem, i.e. a wider tooth, then there might be a jamming problem when the pinion pin was engaging with the tooth but with the narrower tooth things should be OK. The only problem I can think of is that there might be a slight gap or pause in the timekeeping when that narrow tooth comes into engagement with it's pinion?
Mark
Bazyle31/12/2016 20:02:27
6956 forum posts
229 photos
If you think about it the tooth to tooth spacing on one side of the teeth is the same for all, but the thin tooth makes the spacing on the other side off for the last tooth. With a lantern pinion one side of the wheel teeth never touches in a clock that only goes one way, So just mount it the right way round and it will never miss a beat, the other way round might give a problem at the lowest driving weight.
edit Hummm, I'm not sure if that is right.
But if you cut all the teeth again making them as thin as the thin one then you could get them all the same but weaker which would be ok else the one thin tooth is already a fatally weak point.
Edited By Bazyle on 31/12/2016 20:07:41
Mark Bus02/01/2017 17:43:31
50 forum posts
21 photos
Hi,
I looked at the bad tooth again and the space is bigger on one side then the other. But it turns out I made another mistake. I made some multi tooth wheel cutters earlier this [2016] year and the first wheels I cut I used my .125 thick cutter . Then I went to cut the 1 Mod. third and center wheels with my .186 thick Thornton cutter. Unfortunately I forgot to adjust the height of the cutter and I cut the teeth too low. Having tried them out on the depthing tool I still think the wheels would work even with all the errors but I know if I use them I'm going to be thinking about it during the whole construction process so I've decided to make new wheels. It"s just easier.
Mark
