Breva | 23/12/2016 00:13:16 |
![]() 91 forum posts 7 photos | A friend of mine was rebuilding a 3" marine pump and the technical spec for the thread on one end of the drive shaft specified a thread which was described as G3/4A, that is G threequarter A, with a major diameter of some 26mm. Not one we came across before and 3/4" being about 18mm we were a bit puzzled. It seemed to be about 14TPI. Can any knowledgeable person on the forum give me any information as to what we might be dealing with please? John |
Michael Gilligan | 23/12/2016 00:42:39 |
![]() 23121 forum posts 1360 photos | John, It may be to with DIN 908 or DIN 910 parts ... see here: **LINK** http://www.hytec-hydraulik.com/standard-parts/lock-screws.html MichaelG. |
Keith Rogers 2 | 23/12/2016 01:10:44 |
88 forum posts 2 photos | Hi John, It's G series 3/4 BSP Parallell thread that's 14 TPI. Whitworth form (55deg) 1.04" major diameter. Keith. Edited By Keith Rogers 2 on 23/12/2016 01:14:55 |
JasonB | 23/12/2016 07:24:51 |
![]() 25215 forum posts 3105 photos 1 articles | Find that description on european plumbing fittings quite often as Keith says 3/4BSP external See thread designations for what the numbers and letters mean Edited By JasonB on 23/12/2016 07:50:38 |
Breva | 23/12/2016 18:15:07 |
![]() 91 forum posts 7 photos | That was quick! Thank you all for your help. Much appreciated indeed and problem solved. Best wishes to you all for Christmas.
John |
