kevin beevers | 14/12/2016 11:43:33 |
69 forum posts 43 photos | Well nearly got the turd finnished just waiting for son inlaw to come wire it up sorry i have lost some of the photos but some are in my album i cant get them to come on here Kevin |
Bazyle | 14/12/2016 13:24:55 |
![]() 6956 forum posts 229 photos | Ah, Adept blue. Neil will approve |
kevin beevers | 19/12/2016 10:13:55 |
69 forum posts 43 photos | help is needed,now the boxy is up and running do i keep it and sell my other boxy or do i be greedy and keep them both how many of you folks have two lathes ? kevin |
David Standing 1 | 19/12/2016 11:14:19 |
1297 forum posts 50 photos | Posted by kevin beevers on 19/12/2016 10:13:55:
Guilty as charged, m'lud - two lathes.........and two milling machines |
Ajohnw | 19/12/2016 11:22:36 |
3631 forum posts 160 photos | I try to have 2. One Boxford and one much smaller. The smaller one is often problematic.
John - |
Bazyle | 19/12/2016 11:38:28 |
![]() 6956 forum posts 229 photos | Are they both model A bench (rear drive) non-slotted cross slide? edit: and do you have the space for two? Edited By Bazyle on 19/12/2016 11:40:06 |
KWIL | 19/12/2016 12:11:04 |
3681 forum posts 70 photos | Kevin, 4 lathes and 3 mills (different sizes naturally). Always useful to have a second choice! |
Ajohnw | 19/12/2016 12:40:39 |
3631 forum posts 160 photos | On Boxfords it's best to wait for ones that come with as much gear as possible 'cause the costs stack up if they have to be bought even 2nd hand. I'd say a minimum for many is a 3 jaw, 4 jaw face plate and a fixed steady. If the lathe has an imperial gearbox it can be persuaded to cut just about any standard pitch with a selection of change wheels. Not sure how this works out on the metric ones but they do come with a usable screw cutting indicator also I think an 8TPI spindle nose thread. I would avoid the early Model A as I believe it doesn't have the feed arrangements of the later lathe that do this via a slot along the leadscrew. Some people reckon that the ME10 is a load of crap because of the metal removed from the headstock casting. Take no notice. Your very unlikely to notice any difference and these will have a T slotted cross slide. Designs produced for myfords can simply be packed up to correct the centre height differences, then the same techniques can be used. Early examples of the modern design can be affordable now. One size fits in exactly the same footprint as the old ones. Take care though. One I looked at had some sort of fault on the screw cutting nut arrangement. Replacement bits are expensive. Things like steadies are also expensive. The other one didn't have much gear with it. By the time I added what I mentioned cost would have been increased a lot. It also had another problem. Various versions need different numbers of change wheels for screw cutting. This one needed loads of them. Some have some additional levers that allow feeds and pitches to be selected over a limited range. These only need a few change wheels to cut the lot, imperial and metric. There also seems to be an in between model. All of them can be found at reasonable prices apart from some joker that did list on ebay. Both of the ones I looked at were under £1000 and not listed on ebay.
John -
kevin beevers | 19/12/2016 12:56:34 |
69 forum posts 43 photos | well chaps thanks for your comments i do have the space in my small 16x16 garrage but even that seems to be getting smaller,it would be nice to be able to keep everything.Kwill why on earth do you want 4 lathes?and 3 mills (think thats just greedy lol) its got me thinking that 1 decent size lathe poss harrison or on that sort of size would do even for the small work and a decent mill will have to have a good think about this but thanks for your responces kevin |
Chris Evans 6 | 19/12/2016 21:04:41 |
![]() 2156 forum posts | Keep both, a second lathe or mill can save hours not having to break down a set up to do secondary operations. |
