New tool
Tractor man | 10/11/2016 20:34:14 |
426 forum posts 1 photos | Hi all. Having moved home and workshop I'm still not making anything yet. But I did pick up a diprofile classic machine file today and wondered if anyone has any experience with this tool. It's complete and operational but I could do with a manual or instructions on how to set the stroke etc. Hoping it will be useful for filing small parts. Cheers mick |
Mike Crossfield | 11/11/2016 14:54:05 |
286 forum posts 36 photos | If you do a search on Google for "diprofil manual" you will find just what you need. Hth Mike |
Tractor man | 11/11/2016 15:42:21 |
426 forum posts 1 photos | Hi Mike thanks for the tip. I have found the uk supplier and hopefully they will be able to provide a manual. They have the full range of files and hones so I will buy some in and report back on the performance. New machines cost almost ?900 so my barain from the used tool dealer is well worth it. Mick |
Tractor man | 11/11/2016 15:43:13 |
Tractor man | 12/11/2016 13:28:15 |
426 forum posts 1 photos | I have put a couple of photos of the diprofile machine in my albums. I stripped and cleaned it last night and dug out my flexible drive dentist drill to see if it would fit the coupling on the diprofile. Success! It runs like a mini sewing machine, driving a file or hone back and forth. The kit also includes a mini saw blade holder and a carbide scraper which achieves the same results as hand scraping but in miniature and without the elbow grease. Looking forward to playing with it now. Mick |
Michael Gilligan | 12/11/2016 14:59:04 |
![]() 23121 forum posts 1360 photos | Oooh that does look nice MichaelG. |
Tractor man | 12/11/2016 17:21:52 |
426 forum posts 1 photos | There is one on ebay from Bulgaria at 238 plus 95 postage! Wow I paid 40 pounds for mine. True it needed servicing and some new files but it's the bargain of the year. |
Adam Phillips | 12/11/2016 17:55:48 |
![]() 47 forum posts | Hi I have four diprofil hand pieces. they are a smaller version and fit my pendent motor flexible shaft. Three have a set filing stroke length 0.5mm 1mm and 1.5mm the other has an adjustable side to side sweeping action. All came from Febay at less than £40 each. I have found they work best for me with ceramic stones and small Diamond files run at about 10,000 rpm |
Tractor man | 13/11/2016 15:57:59 |
426 forum posts 1 photos | Hi Adam. Those sound like the mini lapping heads which are much smaller than the classic machine. They are still excellent pieces of kit. The classic has a stroke of between 1 and 6mm so quite a bit of grunt for filing. I have put some more pics in my album to show the accessories and some examples of work from the manual. Mick |
Bazyle | 13/11/2016 17:32:11 |
![]() 6956 forum posts 229 photos | What? no pics of the innards when you stripped it? What mechanism does it use to produce the reciprocating motion and is there any vibration damping? Seems like a simple enough project. |
the artfull-codger | 13/11/2016 17:38:23 |
![]() 304 forum posts 28 photos | Quite a usefull tool I also have one' but it's air driven from my compressor as opposed to a mechanical drive, not sure which is the best. probably not a lot in it.
Tractor man | 13/11/2016 20:25:45 |
426 forum posts 1 photos | I didon't think to take ant exploded views. The mechanism is a simple shaft driven eccentric running on bearings which drives a connecting rod mounted on a ball joint to the reciprocating head. No vibration damping evident in the mechanism. The work head is mounted on a sleeve so that it can rotate freely whilst being operated to allow the user to control the direction of the file or hone keeping it in flat contact with the work.mick |
MalcB | 13/11/2016 22:28:59 |
257 forum posts 35 photos | We used them in the toolroom at Ferranti's some years ago on both plastic injection moulding tools and diecasting dies making smaller items. From memory for fine finishing including lapping, polishing, removing blemishes, increasing the draw in dies etc. |
