Wyvern Gears
David Cambridge10/11/2016 19:17:16
252 forum posts
68 photos
Hello All
I’m about 20% of the way into a Wyvern build. I’ve got the two gear blanks from Hemingway but I’m a bit stuck. The gear blanks have the teeth already cut, but as they are so small I’m not sure how to hold them to machine them to the dimensions shown.
They were quite expensive so I’d be grateful for some hints before I mess them up! They need to be bored inside and turned on the outside.
David
JasonB10/11/2016 19:33:01
If you have soft jaws then they can be machined to suit the gears.
If not then chuck a short bit of aluminium a bit larger in dia than the gear and bore it out to a good fit over the gear teeth, mark the bit of bar so it can go back in the chuck the same way and then remove and saw a slit lengthways.
Slip the gear into your "collet" and put them in the chuck and machine away. The slot will allow the collet to close up tight onto teh gears and being a softer metal won't damage the gear.
You may also be able to use a 5/8" collet or a 16mm ER collet with a packer at teh back end so it closes evenly.
Chris Gunn11/11/2016 17:14:36
459 forum posts
28 photos
David another alternative method would be to make a 3/8" diameter mandrel to slip the gear on, tap say an M5 hole in the end, and hold it in place with a thick washer and a socket head screw, then machine the teeth away gently. Then you can turn the gear around and do the other end.
Chris Gunn
David Cambridge11/06/2017 19:52:56
252 forum posts
68 photos
Hello all.
Embarrassingly , I’ve still not progressed this very far, despite the fact that it’s more than 6 months since I asked the original question.
Anyway, my question today is how are the gears actually fixed to the crankshaft. I can see there is a 1/16 notch cut into the crankshaft gear, and a 1/16 hole drilled into the camshaft gear, but it’s not clear to me how these are used to lock the rotation of the gears to the rotation of the shaft. I’m guessing it involves pins into the shafts, but I can’t see this marked on the plans.
Thanks in advance,
David
JasonB12/06/2017 16:32:31
Press fit pin into shaft, could Loctite if not happy with tightness of press fit or even use a taper pin.
John Purdy12/06/2017 18:11:18
431 forum posts
252 photos
David
As Jason says a short pin is pressed into a 1/16" hole in the crankshaft to key that gear. I fixed the one on the camshaft on mine with a 1/16" roll pin. You might also read my post of 02/11/15 in the "Drawing Errors and Corrections" section of this forum (if you haven't already) as there are a number of problems with the drawings for the Wyvern.
David Cambridge12/06/2017 23:10:59
252 forum posts
68 photos
Thanks both
