Plate Threads
Lynne | 02/11/2016 23:35:24 |
117 forum posts 32 photos | Hi, wheel posts are threaded 3BA, so the spares catalogue tells me The tapping hole for 3ba is 29 or 3.4mm, and these will not go through the hole in the plate I am looking at. I have tried to determine the thread from the range of taps I have , but no success. Any suggestions as to what may have been used. Thanks, Lynne
Michael Gilligan | 03/11/2016 00:09:02 |
![]() 23121 forum posts 1360 photos | Lynne, What clock & what catalogue ? MichaelG. |
Bob Stevenson | 03/11/2016 00:14:35 |
579 forum posts 7 photos | ...........Michael beat me to it!........
If you want to know what thread then shave down a spill of softwood and (carefully) screw it into the threaded hole then compare with a thread guage.
"wheel posts" are usually called 'arbours' but they are not usually threaded....... |
julian atkins | 03/11/2016 00:19:59 |
![]() 1285 forum posts 353 photos | Hi Lynne, If you want a pukka traditional job the frame posts are secured with tapered pins, not threaded and with nuts added. Cheers, Julian |
Brian Wood | 03/11/2016 08:45:18 |
2742 forum posts 39 photos | Hello Lynne, |
Bob Stevenson | 03/11/2016 09:01:52 |
579 forum posts 7 photos | .....Hello Brian,...I have sent you an email just a minute ago! |
Lynne | 03/11/2016 18:24:15 |
117 forum posts 32 photos | Thanks for the responses. Michael & Bob. 8 day longcase, english movement, well, the name on the brass face is Geo. Booth, Manchester. Hasn't ticked for 40 years that I know of. Weights, one cast iron, could be original, the other, pretty poor lead casting. Also missing the gathering pallet, which will be a challenge. The hands need attention, minute hand broken, but I have the pieces. There is more. Catalogue. Meadows & Passmore. They describe them as Rack & minute wheel studs. Cousins describe them as Rack & lifting piece posts/studs. The 22mm length is insufficient, I need 25mm, so I will have to do a repair. Minute post is sound, Maj. thread dia. is 3.43mm, hole dia. 3mm. tread pitch using BA guage would appear to be 3BA. So, what to do? drill 3.4 and tap 3BA, or try to match the original form. Regards Lynne
Michael Gilligan | 03/11/2016 19:20:31 |
![]() 23121 forum posts 1360 photos | Thanks, Lynne Here's the Rack Stud, for everyone's reference **LINK** http://www.m-p.co.uk/muk/parts/chap03/rack-stud-1459000315.htm Proper 'conservation' would mean modifying the new component [or making from scratch] to fit the existing tapped hole ... but only you can decide whether that is appropriate. MichaelG.
