Length and advice on design
Brian H | 22/10/2016 20:37:23 |
![]() 2312 forum posts 112 photos | I have a Boxford AUD with 16 inches between centres on a 36 inch bed and I want to fit a splashback, BUT. I have found a drawing of a splashback but it appears to be for the long bed (28 inches between centres) version with a length of 41. 5 inches ( the splashback that is) Can someone tell me what the splashback length would be for my version? ALSO, having spent some time obtaining meaurements and drawing and cutting templates, I now find that the lathe would have to be moved away from the wall by about 4 inches to fit the splashback in, unless there is a way of making a splashback to fit flush against the wall. (almost) any suggestions welcome. Edited By Brian Hutchings on 22/10/2016 20:39:14 |
Mike Lightfoot | 22/10/2016 21:44:05 |
76 forum posts 24 photos | Just how close to the wall is your lathe? If your not to bothered about it looking like the original how about just sliding a piece of sheet say 16s gauge down behind it slight kink at the bottom to sit in the tray job done. |
Bazyle | 22/10/2016 21:50:46 |
![]() 6956 forum posts 229 photos | An AUD has to be easier than a bench version with the motor and countershaft both sticking out the back. If it is happy against the wall all you need to do is drop down flush with the wall to one inch above the drip tray, bend forward almost 90 degrees so there is a little bit of a slope on the ledge, then a turn down at the edge into the drip tray. Width is the width of the drip tray. There are more than 2 bed lengths so easiest to measure off the job than risk someone giving you a measurement off a different one. |
Brian H | 23/10/2016 07:48:04 |
![]() 2312 forum posts 112 photos | Posted by Mike Lightfoot on 22/10/2016 21:44:05:
Quote: "Just how close to the wall is your lathe?" The edge of the tray is against the wall so your suggestion makes complete sense but I was worried in case I had overlooked something vital.
Edited By Brian Hutchings on 23/10/2016 07:48:40 |
not done it yet | 23/10/2016 09:07:59 |
7517 forum posts 20 photos | Surely the length for the 16'' between centres would be 12''shorter than that for an identical lathe, but of 12'' less between centres? Only if the lathes have different layouts, other than the bed length, would the splashback need to be different other than in length - or are we missing some other details?
The only doubt seems to be the actual bed length of the longer lathe (you say''it appears to be for the long bed). One question might be whether the tailstocks are identical for both variants (look at lathesdotco pics?). |
