ICEpeter | 27/09/2016 23:09:28 |
5 forum posts 5 photos |
Hello, I need some help figuring out the wiring connections for a single phase Invensys Brook Crompton motor I removed a while ago from my Myford Super Seven lathe and replaced it with a Newton Tesla frequency drive. I did not make notes of the wiring upon removal and did not keep the old switch gear. I want to run the motor in one direction only without reverse of direction. The motor has a capacitor and start and run windings. Being not well versed in electrical matters, I wonder if one of this sites model engineers know how to wire it to run in one direction only and what additional switch gear may be needed. The above picture shows the terminal board and terminals, and the terminal markings. In its original application, the motor had four leads attached to the terminals as shown in the picture. I would be very grateful for advise. Thanks. Peter J. |
Brian Oldford | 29/09/2016 10:25:47 |
![]() 686 forum posts 18 photos | As this has been here unanswered for a day or so I'll throw in my two-penny-worth. I believe it to be a conventional single phase motor with centrifugal switch in the start winding circuit. For your purpose you'll need to identify the "ends" of the two windings with a continuity tester. One that is done all you need to is wire the two windings in parallel. The supply should be switched in the live. If the motor starts in the wrong direction simply reverse the connections of one of the two windings. I hope that helps. |
Neil Wyatt | 29/09/2016 12:18:17 |
![]() 19226 forum posts 749 photos 86 articles | Sorry Peter, Your post seems to have escaped notice until now. MEW 244 had an article covering the wiring for most common types of single-phase motors. The author is a regular on here so hopefully now this thread has been bumped he will be able to advise. Neil |
ICEpeter | 01/10/2016 19:39:39 |
5 forum posts 5 photos | Hello Brian and Neil, Thank you very much for your reply. I have not made much progress / any progress to this point and still trying to figure the wiring out. Have not done Brian's recommendation, have to get a suitable tester first. Hope to get more feed back from fellow model engineers with knowledge of this particular motors wiring. Thanks to all for their assistance in this matter. Peter J. |
ICEpeter | 05/10/2016 23:37:58 |
5 forum posts 5 photos | Gentlemen, I figured my wiring out and it is as follows: Power L connects to U2 and connects to R Power N connects to U1 and connects to S On / off switch implemented in power L feed wire. In this configuration, the motor runs as intended in one direction only without reversing of direction. Thanks. Peter J. |
john fletcher 1 | 06/10/2016 10:13:11 |
893 forum posts | I hadn't saw request until today, anyway you have sorted it yourself, I bet you feel 10 feet tall now. If you need forward and reverse you need to exchange the positions of R & S, leaving U1 & U2 where they are. Pleased to see that important Green and Yellow cable John |
ICEpeter | 09/10/2016 18:54:24 |
5 forum posts 5 photos | Hello John, Thank you very much for your comment and information. Once I solved my problem, I did feel taller but not quite the 10 feet you mentioned. I believe I only added about 6 inches to my 6 foot 2 inch frame. Thanks for your info, it will be useful when I may change the motor direction down the road in future. Peter J. |
Alan Redgrave | 07/12/2020 17:32:09 |
32 forum posts | Hello everyone, Just a quick word to say "Thank-you" to all the contributors on this thread-------- I know it's a wee bit late ( 4 years and 1 month ) but I have just had exactly the same problem as ICEpeter and can now use this info to re-wire my Boxford........Just for interest sake but the Tech. guy at Brook Crompton was baffled...More power to the Forum !! Thanks again
Alan R |
john fletcher 1 | 07/12/2020 18:11:20 |
893 forum posts | Out of interest, about a year or two ago a friend had a Brook Crompton Motor, capacitor start and capacitor run with an unusual centrifugal switching arrangement, he asked if I had a copy of original circuit diagram. We had the motor on his bench, he rang Tyco at Doncaster which is now owners of Brook Crompton and who are apparently owned by a company in China. On the phone the 'Tec' said that's not one our motors mate, in spite of what the name plate said, we couldn't believe it. Within the hour, some else phoned and asked had we sorted to motor and could they have a copy of the circuit diagram. John |
