What is best for general use?
Colin Osborne | 21/09/2016 16:11:40 |
50 forum posts 35 photos | Hi all, I have been given a Kamasa 506 CBG bench grinder. The wheels that came with it ( 1 med, 1 fine) are okay but I seem to have more stone dust than metal dust! I presume they must be at the cheaper end of the scale. I only have a small workshop, but I do have an SC3 lathe and a bench drill, (which, I wish in hindsight, I had bought a small mill instead!) and I do not want my tools, etc, covered in dust! What are my best options for wheels to keep the dust to a minimum? I have not got around yet to tool making/sharpening, But it will not be too long, I hope. So, most of the work is general purpose, any suggestions? cheers, Colin. |
Vic | 21/09/2016 16:46:06 |
3453 forum posts 23 photos | Bit spendy but lots of folks like these for sharpening wood turning tools: |
Colin Osborne | 21/09/2016 17:02:42 |
50 forum posts 35 photos | Mmmm, see what you mean about 'bit spendy', Perhaps later when I get a bit more involved with the hobby. Us pensioners have to be a bit careful with the pennies Thanks for replying though! Colin. |
Vic | 21/09/2016 17:21:31 |
3453 forum posts 23 photos | A decent engineers suppliers like Cromwell or Buck and Hickman should be able to supply good quality wheels. |
Neil Wyatt | 21/09/2016 17:32:50 |
![]() 19226 forum posts 749 photos 86 articles | It is more likely that the grade is wrong for what you are sharpening. See if you can get the code off the label (plenty of sites on the web explain the codes) and get something better suited to your needs. Neil |
Colin Osborne | 21/09/2016 19:20:40 |
50 forum posts 35 photos | Thanks for the suppliers, Vic. I'll look them up on the web. And, I think you could well be right, Neil, I'm not sure where the grinder came from but I don't think it was used for precision work! Most probably from a garage or somesuch. But I'm grateful for it anyway, I don't like turning anything away that's free. Colin. |
Peter Tucker | 21/09/2016 19:54:22 |
185 forum posts | Hi Colin, The "soft" wheels on your grinder aren't green are they? I they are then they are for sharpening tungsten carbide tooling, and are not cheap. Hope this helps. Peter. |
Colin Osborne | 21/09/2016 20:31:33 |
50 forum posts 35 photos | Hi Peter, No, they are the usual grey. I've yet to have a look at the label's, but I'm sure they are not going to be anything special! I have ordered a couple of wheels from ARC, plus some other bits and bobs, and I have an apology to give to Neil. It wasn't until I had placed the order that I saw his book on the mini-lathe. By that time I had already ordered the one by David Fenner!! Next time I order, Neil........! Cheers, Colin. |
