Eric Cox | 21/09/2016 10:33:24 |
![]() 557 forum posts 38 photos | Should the RH wheel on an off hand grinder be held in place with a RH or LH nut. Mine is held with a RH thread and keeps coming loose. I'm wondering if the armature has been put in back to front. |
Mike Poole | 21/09/2016 11:06:16 |
![]() 3676 forum posts 82 photos | Looking at the wheel from the right hand side it should rotate anti-clockwise and therefore a RH nut should tend to tighten, the left hand end should have a LH nut. The wheel rotation should tend to push the work onto the rests. Mike Edited By Michael Poole on 21/09/2016 11:06:52 |
Brian Wood | 21/09/2016 11:55:05 |
2742 forum posts 39 photos | Hello Eric,
Eric Cox | 21/09/2016 15:30:53 |
![]() 557 forum posts 38 photos | I would have thought that the RH wheel would have a LH thread so the anti clockwise rotation of the wheel (viewed from the side) would tighten a LH nut. |
Keith Long | 21/09/2016 16:06:00 |
883 forum posts 11 photos | Eric, think about start up. The motor shaft spins and the wheel tries to stand still and resist it. That results in a torque on a right hand nut TIGHTENING the nut to make sure the wheel is secure. The same argument applies to the opposite end of the grinder which is why the left hand wheel (standing facing the front of the machine has a left hand thread. The only time the right hand thread on the right hand wheel would tent to come undone is if the motor shaft suddenly seized and the wheel tried to carry on. Normal run down on switch off takes long enough for the loosening torque to be low enough not to have an effect. |
Mike | 21/09/2016 17:28:48 |
![]() 713 forum posts 6 photos | I'm on my third grinder in around 45 years, and all have had a right-had thread on the right, and a left-hand thread on the left. I've never had a wheel come even slightly loose. Makes me wonder if Eric's grinding wheels have been fitted with the correct washers. I've just had a quick "Google", and a Health & Safety Executive document on grinding wheels can be downloaded free at https://www.staffs.ac.uk/assets/hsg17_tcm44-45519.pdf |
frank brown | 21/09/2016 17:33:21 |
436 forum posts 5 photos | To loosen any grinder nut it needs smacking in the direction of stone rotation. Doing 10 times a day on my disc cutter. Work it out. Frank |
Neil Wyatt | 21/09/2016 17:35:28 |
![]() 19226 forum posts 749 photos 86 articles | Easy way to think about it is this - imagine holding a spanner stationary on the nut and turning the wheel. If this would tighten the nut, it is the correct hand. Make sure you have both the proper card and metal washers in place. Neil |
