Rainbows | 16/09/2016 20:34:06 |
658 forum posts 236 photos | I have a bench grinder and the left side nut won't thread on, it james after a few turns. The issue is kinda increased cause as a bench grinder spindle it is a pain keeping the spindle still. Further more it is a left hand thread so no tap or dies.
Anyone got hints for getting a looser fit on the threads? I would use a die to clean up the spindle generally but I don't feel like buying a left hand die just for this. |
John Rudd | 16/09/2016 20:38:12 |
1479 forum posts 1 photos | Thread chaser or needle file? |
JasonB | 16/09/2016 20:41:12 |
![]() 25215 forum posts 3105 photos 1 articles | Thread restoring file, they don't mind if its L/H or R/H |
not done it yet | 16/09/2016 21:54:07 |
7517 forum posts 20 photos | Add a thicker washer or washers, so avoiding those threads?
Make a pinch collar for the section of plain shaft and hold the shaft still with an appropriate spanner, wrench, etc?
Is it the nut, or the shaft threads that are galled/stretched/otherwise damaged? No point in holding one, if the other is at fault. |
