Mike Crossfield | 24/08/2016 09:08:05 |
286 forum posts 36 photos | I'm considering fitting a DRO to my Dore Westbury milling machine. There is not much space for the scales on this small mill, and there are many options on DROs. I would therefore be very interested to hear from anyone who has experience of installing a DRO on a DW.
Brian Wood | 24/08/2016 10:15:35 |
2742 forum posts 39 photos | Hello Mike, I fitted a 2 axis Newall Microsyn 10 system with a Topaz Mill readout, equipped with the PCD function. On the quill I have fitted a simple one axis scale from Machine DRO It was not cheap but the installation is neat and out of the way and takes up so little of the space available. The table travel scale is 300 mm, the cross slide 175 mm. The system has been operational since early 2004 Regards Brian Edited By Brian Wood on 24/08/2016 10:21:32 |
Mike Crossfield | 24/08/2016 10:30:49 |
286 forum posts 36 photos | Thanks Brian. PM sent. |
Ajohnw | 24/08/2016 11:39:38 |
3631 forum posts 160 photos | Depending on how DIY you want to go Renishaw might be an option. I think that the tablet based display and associated hardware is compatible with them. I don't have a link for that but it can be found on the web. I have also seen a site that sells the parts. That seems to be this one now John - Edited By Ajohnw on 24/08/2016 11:42:03 |
Les Jones 1 | 24/08/2016 11:59:32 |
2292 forum posts 159 photos | Hi John, Les. |
Ajohnw | 24/08/2016 13:00:23 |
3631 forum posts 160 photos | Posted by Les Jones 1 on 24/08/2016 11:59:32:
Hi John, Les. Yes. That's the one.
John - |
Michael Gilligan | 24/08/2016 13:50:49 |
![]() 23121 forum posts 1360 photos | Posted by Ajohnw on 24/08/2016 13:00:23:
. John, It would be a great help, to others that are interested, if you could be a little more specific. MichaelG. |
Ajohnw | 24/08/2016 16:43:12 |
3631 forum posts 160 photos | From memory there was some comment that it used ascii. From what I can gather it uses the signals that many dro sensors put out and can even cope with pure quadrature outputs which are just pulse trains, 2 in antiphase so that direction can be sensed. It may well be able to cope with ascii outputs from sensors as well as I believe some do that. What isn't clear when I look at the site is what does what. For instance it states that a board can be easily converted to use quadrature but from what I can see no signs of how. It shouldn't be difficult to handle this in a micro because it's just a case of counting pulses and noting which one changes first so that direction can be detected. As for instance this is how car steering angles are detected. Linear motion is no different. Being fair to the man who has done it supporting something like this can be pretty onerous for a one man band and the mixed signal board seems to be pretty new. The unit that has to be built or bought may well use ascii to transmit data to the tablet via bluetooth but that's not really relevant because if some one dug deeply into a one piece commercial unit it might do the same to communicate with the display. All most certainly if it used a touch screen and probably in other cases as well. I have hand cranked simple displays in the past but there comes a point where it's easier to tell a display unit to do it rather than set dots or segments etc. Bluetooth may be a weakness, noise immunity, but it seems some have converted to serial, possibly even usb. Some are using USB cable for sensor leads as they are shielded and also the connectors at times. John - |
Michael Gilligan | 24/08/2016 20:04:43 |
![]() 23121 forum posts 1360 photos | John, Please correct me if I am wrong, but; I think the gist of it is:
Sounds simple [if you're clever enough to do the magic] !! MichaelG. |
Les Jones 1 | 24/08/2016 20:37:04 |
2292 forum posts 159 photos | Hi Michael, Les. |
Michael Gilligan | 24/08/2016 21:30:30 |
![]() 23121 forum posts 1360 photos | Thanks for that, Les MichaelG. |
Ajohnw | 25/08/2016 00:02:41 |
3631 forum posts 160 photos | I wasn't too specific about what the converter puts out to the tablet because he could use a number of formats. It could turn out for instance that BCD (use google) would be more efficient than ascii. If I did it and wanted to maximise the data rate the converters could output I might use that as it would probably be easier to handle at the tablet end than binary as converting that to decimal is a complete and utter pain. Simple code but given big numbers it takes a long time to run. Most uP's will handle BCD conversions well. It doesn't matter much really. The main aspect is update rates and I think I have seen comment of 10 per sec on 4 scales which is fine for a DRO. One change he has made is to switch internally to metric. From what I have read 5um scales should be fine. 1um may not be but frankly if some on pressed many milling machines with their hands the reading could change by more than that. Also looking at various scales 5um seems to be at the higher end of realistic. If some one is going in this direct they will have to check that the scales they want to use are compatible. There may be a need to ask about scale length / resolution on bigger machines. I doubt it but it might be worth asking. He doesn't give any info on using USB rather than bluetooth. I get the impression that people who have done this have grafted some small board or the other onto the main board in place of the bluetooth one. John - |
Ian P | 25/08/2016 08:44:14 |
![]() 2747 forum posts 123 photos | Posted by Ajohnw on 24/08/2016 11:39:38:
Do you have any indication of pricing for the RLS modules? They look most interesting! The website does not have prices and it seems they quote only when one makes an enquiry Because of their small size I would contemplate incorporating one and its scale 'inside' the lathe topslide. Ian P
Mike Crossfield | 25/08/2016 08:51:15 |
Like Ian, I found the RLS scales very interesting, but couldn't find prices or a stockist. Any further info appreciated. Mike |
Michael Gilligan | 25/08/2016 09:01:45 |
![]() 23121 forum posts 1360 photos | Les, If you have the time; could you please clarify something for me? The posts dated 04-Jan-2015, on this page concern the possibility of using a computer mouse with Yuriy's DRO. http://www.yuriystoys.com/2013/10/mixed-scale-dro-controller-project.html He seems rather circumspect about this; but I don't understand why ... I thought most mice used simple quadrature encoders. Thanks MichaelG. |
Ajohnw | 25/08/2016 09:59:13 |
3631 forum posts 160 photos | I just used the 2nd link I posted and clicked on linear and then on one of there models and details in the lower right hand of the page have to be filled in and out pops a price and delivery time. This is the incremental scale page. There is another for absolute
John - |
Michael Gilligan | 25/08/2016 23:05:04 |
![]() 23121 forum posts 1360 photos | Posted by Ajohnw on 25/08/2016 00:02:41:
He doesn't give any info on using USB rather than bluetooth. I get the impression that people who have done this have grafted some small board or the other onto the main board in place of the bluetooth one. . John, Yuriy commented [20-Dec-2013] on this thread http://www.model-engineer.co.uk/forums/postings.asp?th=57456&p=5 MichaelG. |
Yuriy Krushelnytskiy | 26/08/2016 03:04:34 |
11 forum posts | John, There really isn't that much to it. If you're using Arduino, USB should just work with most boards. FTDI-based boards work fairly well. The newer ones "often work" (the driver TouchDRO uses in theory supports all Arduino version and more, but it's been more reliable with FTDI). That said, there is no reason to use USB and all sorts of reasons to not use it. BlueTooth is much more reliable in a workshop environment. Unless you have a tablet that has USB but no BlueTooth, I would skip USB and stick with wireless. Regards Yuriy Edited By Yuriy Krushelnytskiy on 26/08/2016 03:05:15 |
Ajohnw | 26/08/2016 09:48:52 |
3631 forum posts 160 photos | Thanks Yurly. I'd use bluetooth. I just mentioned that there may be interference problems from say a poorly wired inverter on the machine but at circa 2.4ghz I would have thought even that would be unlikely. The leads to the sensors could be shielded which should help at that end. Also picking scales that have fairly low drive impedances which I suspect many will have.
John -
Michael Gilligan | 26/08/2016 10:38:04 |
![]() 23121 forum posts 1360 photos | Posted by Ajohnw on 26/08/2016 09:48:52:
. If that's your biggest problem, John, you must live a very contented life. But I could help with that if you like: A straight swap: Your "rather expensive iPad" for my little-used Tesco Hudl MichaelG. |
