Kunifer boilers
Ebenezer Good11/08/2016 10:22:46
48 forum posts
Hi, I have just been given some 150mm Kunifer pipe 4mm wall, has anyone used this for building a boiler before? My Internet searching has drawn a blank.
duncan webster11/08/2016 11:39:35
5307 forum posts
83 photos
There is a lot of good information at **LINK**
There are 2 grades, I'm not sure it makes any difference. There is a UK supplier at **LINK**
if you give them a ring and ask to speak to techy people they might help. At the end of the day it's down to your boiler inspector
fizzy11/08/2016 12:24:23
1860 forum posts
121 photos
Im only guessing here(its been 30 years since I last sat in a metallurgy class) but nickel is added to the copper to make it more ductile, and a ductile boiler isn't something I want to be near. Also the boiler regs in UK only allow for copper or steel in construction (Southern Fed) so you aren't likely to get it passed an inspector.
duncan webster11/08/2016 12:53:27
5307 forum posts
83 photos
I'd much rather be near a ductile boiler than a brittle one!
Neil Wyatt11/08/2016 17:15:00
19226 forum posts
749 photos
86 articles
I like the idea that a copper-nickel alloy hull can have a "payback period as short as 32 years" - that's long-term financial planning!
fizzy11/08/2016 18:52:32
1860 forum posts
121 photos
I wouldnt want to experience either. I once made a simple boiler out of exceptionally thin copper just to see if it would hold out, it did but it got thrown in the scrap bin anyway.
julian atkins12/08/2016 00:27:41
1285 forum posts
353 photos
I cant comment on the above.
I had a short length of 'copper alloy' ex RN tube given to me many years ago. Aparently used on very high pressure steam lines.
I cut it up for various things including a number of displacement lubricator tanks for hydrostatic sight feed type displacement steam oil lubricators on locos all tested to working pressure of the loco. I have not the slightest doubt it was the copper nickel alloy referred to above. It silver soldered beautifully.
Cheers,
Julian
Simon Collier12/08/2016 07:54:22
525 forum posts
65 photos
If it is any help, the Australian code allows cupro-nickel alloys 400 Monel and R405 Monel.
Ebenezer Good12/08/2016 09:55:53
48 forum posts
Thanks for the advice, I hadn't considered it might not be approved for use.
