Michael Checkley | 02/08/2016 22:36:44 |
![]() 121 forum posts 66 photos | Evening! I`m trying to identify a crankshaft that was used in a friends model aero engine project as I would like to build a similar engine. Sadly he has passed away so I cant ask him where he got it from but I have been told it came from a chainsaw. I`m not having much luck identifying a crankshaft long enough to take 2 bearings. I have attached some photos and a drawing, if anyone has any experience in engines from chainsaws, cut off saws or similar sized engines any help or direction would be much appreciated. |
RJW | 03/08/2016 13:46:25 |
343 forum posts 36 photos | Michael, does that rectangular stub on the end of the crankpin screw out by any chance? It looks very much like a Velo-Solex crankshaft, the big end on those is held in place by a bolt screwed into the end of the crankpin, If it is a Solex, the centre waisted section carries the driving hub which rubs on the tyre and has another bearing near the taper which is located in the other half of the crankcase, I've got one of those engines stripped down but it's in France, so can't offer any photo's unfortunately. John.
Edited By RJW on 03/08/2016 13:55:13 |
Michael Checkley | 04/08/2016 21:17:51 |
![]() 121 forum posts 66 photos | Hi John, Thankyou for the info, I will check out Solex engines and see if I can see a match. The flats on the end of the crank pin were ground on to accept a 'new' section for the crankshaft, the old one being 3 pieces pressed together. I`m thinking the half of the crankshaft I have must be screwed or pressed together as I cant see how they can press the bearing over a ~1mm step. The plan at the moment is to find something similar rather than an exact replacement which is still proving difficult and the technical departments of the major manufacturers don't seem interested in helping. A repair shop may be more helpful which is this weekends challenge. |
clogs | 05/08/2016 07:14:34 |
630 forum posts 12 photos | HI Michael, u will find the same style crankshart on most petrol engined strimmer/brush cutter's..... there quite a few different sizes.......most engine range from 20-50cc.........the cranks seem to last for ages, it's usually the carb or the electric's that stop em running........... I live too far away but my barn has at least 10 junker's (kept just for spares, hahaha) a good place to look is the local tip, it seem's that they r now cheap enough to throw away when they stop running.... good luck.....Clogs....... |
Ian S C | 05/08/2016 13:04:34 |
![]() 7468 forum posts 230 photos | I'v got a number of small engines from 15 cc to 40 cc, the ones with two crank cheeks are pressed together, some have plain bearings, others either needle rollers, roller, or ball bearings. The bearing on your crank should be on a step the same or larger diameter as the bit to the left by the taper. Ian S C |
RJW | 05/08/2016 13:41:19 |
343 forum posts 36 photos | Michael, I've taken a look at a few images of the Solex crank, and although the web is similar, the mainshaft is much longer than that on yours, John. |
Michael Checkley | 06/08/2016 15:12:54 |
![]() 121 forum posts 66 photos | I have had a look at scooter crankshafts and although it looked quite positive at first I think the one I have has come from a chainsaw, albeit an old one. My only requirement now it to find one with a similar diameter shaft and length (before the taper), if that search fails then I`m going to investigate making one, materials and heat treatment e.t.c I called in to my local lawnmower/chainsaw repair shop and he looked at me in horror and basically refused to help me without a specific code to order an equivalent replacement. He was not prepared to help and show me anything similar incase anything came back on him in the event of the part failing. How ridiculous, no wonder this country is being left behind when it comes to innovation. |
Ian S C | 07/08/2016 12:01:17 |
![]() 7468 forum posts 230 photos | A model aircraft engine with a crank that size is going to be quite large. There is a fair bit on the net about using weed whacker motors for model aircraft, maybe one of those sites might help. Ian S C |
Tim Stevens | 07/08/2016 21:13:53 |
![]() 1779 forum posts 1 photos | The GN motor car had a similar design of crank, but that was in the early 1920s. And if you find a spare one, some GN owner will bite your arm off for it. Cheers, Tim |
