myford vm-f milling machine
clogs17/07/2016 17:50:28
630 forum posts
12 photos
Hi Guy's,
just bought an as new Myford VM F milling machine .......
had to rotate the head to get it in the workshop...3x19mm nuts...but it won't go back !!!!! yes, have re loosened them again..........have looked for a locking pin / plunger to no avail.......I need to do a quick job...........ooops
any help appreciated.......also tried Rodean for a workshop manual as the original is lost......where else can I try.....
many thanks Clogs
alan-lloyd17/07/2016 18:35:18
183 forum posts
How about lathes.co.uk
John P17/07/2016 19:11:03
451 forum posts
268 photos
Hi Clogs,
When you rotated the head it is possible that one of the tee nuts has
got caught up in the access slot where the tee nuts fit in the radial
"T" slot .This is most likely to be in the position facing forward when
you stand in front of the machine ,slacken each of the nuts a little and
try to rock the head a little whilst just feeling if the nut /tee bolt is in position.
My Warco mill had a similar situation until modified.
Good luck.
