Without access to a surface grinder.
OuBallie | 07/07/2016 12:48:12 |
![]() 1181 forum posts 669 photos | Photo says it all. I do have a small high speed drilling machine, Dermel equivalent and angle grinders. Suggestions please, as all eight need doing. The Warden kit is mocking me, so time to pull finger. Geoff - Overhaul the SU carb next. |
Phil P | 07/07/2016 13:08:39 |
851 forum posts 206 photos | I would hold them in the lathe and use your dremel in the toolpost to gently remove the dimple. Have you checked your cam followers they are a bit more of an interesting challenge to re-grind to the correct radius. Phil Edited By Phil P on 07/07/2016 13:15:44 |
Chris Evans 6 | 07/07/2016 15:10:47 |
![]() 2156 forum posts | Collet chuck on the lathe and turn with carbide then polish up. Or send them to me and I can grind them. |
Gordon Fowler | 07/07/2016 20:54:36 |
21 forum posts 16 photos | The tappet screws can be done with a tipped tool, for the cam followers I made this, goes in place of the rest. |
Gordon Fowler | 07/07/2016 20:57:56 |
21 forum posts 16 photos | |
OuBallie | 11/07/2016 14:58:03 |
![]() 1181 forum posts 669 photos | Thanks for the responses. Cam followers appear fine, BUT will check for uneven contact with trial assembly. Thanks for the offer Chris, and I will take you up on it if my grinding proves less than satisfactory, after I put the camshaft, block and valve gear back together and rotate the cam to check followers/lobe contact. Grinding done, using the high speed drilling machine as per photo, and in a typical Heath Robinson fashion by sliding the vice around the table. A quick lick on X-fine diamond card and result as seen. Easier than I expected. Geoff - SU carb, that will replace the original, stripped for cleaning and refurbishing. Edited By OuBallie on 11/07/2016 14:58:40 |
