charadam | 06/06/2016 18:50:48 |
185 forum posts 6 photos | Hello all. I have done my usual and over-researched and over-thought this. Please help me decide which DRO to buy! I'm mainly looking for ease of installation. Thanks for any thoughts. Charles
Stuart Bridger | 06/06/2016 19:13:26 |
566 forum posts 31 photos | Probably not much help, but I also put extensive research into a DRO for my Chipmaster. My decision was not to bother. The installation was going to be a hassle and I never really came to a good solution for the amount of space the cross slide scale would take up. Even more significantly I found with more time on the lathe that I really didn't need a DRO. I do have a DRO on my mill though and would not do without it. |
Jon | 06/06/2016 19:39:23 |
1001 forum posts 49 photos | Dead easy to do on Chippies same as most other English lathes they have at least two flats on rear for taper turn attachemnts. Screw scale on them usually without the need for shims, its English quality. Normal C type glass scale with cover. Cross slide easier than most get the magnetic and mount reader outboard. Will lose around 1/4" as tail stock butts up to cross slide. Readers under the top aluminium plate level with coolant upright no need to go this far. Tailstock will need to make up a clamp to go round quill. 3 axis on mill also all C type glass. |
