Domed end cap
richard 2 | 06/06/2016 17:52:15 |
127 forum posts | I have acquired an Alemite 500 grease gun and am currently making a nozzle to fit Myford lathe nipples. My problem is that the end cap of the body is domed with two adjoining holes. As the cap is domed I cannot use a large washer and bolt to block them and they need to be oil-proof as the body will be full of oil; though not under pressure. In Guy Lautards(?) instructions the end cap of his gun was flat, not domed. Can someone tell me how to block these holes in the end cap. I am not up to making a new cap as it is 1.25" bore and with an internal thread I certainly could not cut. I have made Brian Forrests designed nozzle for Myfords and it works a treat. Oiling the lathe is now a pleasure, especially as I made the bit that does the job. Many thanks Richard. |
Gordon W | 07/06/2016 09:46:20 |
2011 forum posts | Assuming the two holes are the small breather holes- just solder them up, or I suppose jb weld or similar will do the job. Clean first of course. |
richard 2 | 08/06/2016 11:34:36 |
127 forum posts | Thanks Gordon The two holes were for the ram which is no longer required as oil does not need forcing into the pump. But I will take your advice and fill the holes with solder using a small piece of brass gauze as a base and will blanket tis will solder. Richard. |
Dennis WA | 08/06/2016 12:10:01 |
![]() 79 forum posts 5 photos | Richard, You posted: "I have made Brian Forrests designed nozzle for Myfords and it works a treat." Where can I find details of this nozzle? Thanks Dennis |
richard 2 | 09/06/2016 08:22:20 |
127 forum posts | Denis, Brian Forrest's article "An Oiler for the Myford lathe" appeared in issue 178 p.46. Because my workmanship is of a minus standard I modified his design and made the body in three parts. Mine is made of ali as I have lots of it but I would have preferred brass if available. If you are anywhere near West Sussex you would be welcome to come and try my Reilang oil-can and see for yourself. Regards Richard. |
Douglas Johnston | 09/06/2016 08:50:26 |
![]() 814 forum posts 36 photos | Hi Richard- I had the same problem a while ago and used JB Weld epoxy and that worked perfectly with no oil leaks after more than a year. Doug |
Dennis WA | 09/06/2016 09:25:04 |
![]() 79 forum posts 5 photos | Thank you Richard. Despite their price, I use Reilang oil-cans. Like many other folk I have found them to be the best! Dennis |
richard 2 | 09/06/2016 14:27:06 |
127 forum posts | Hi Doug, Thanks for reply. I have just ordered JB Weld epoxy and hope this will do the job. Regards Richard. |
