Here is a list of all the postings Dennis WA has made in our forums. Click on a thread name to jump to the thread.
Thread: Model engineering suppliers (near Johannesburg) |
03/06/2022 14:08:11 |
Joe you wrote: The only modelling club worth 'something' is the Centurion Society Of Model Engineers - located at 193 Kwikkie Cres, Zwartkop, Centurion, Pretoria direction - google for contact info - the members may have a better idea of sources on interest. No modelling club in JHB For the record the Rand Society of Model Engineers (founded 1934) is still operating in Florida Park, 15 kilometers West of the Johannesburg City Centre. It is open to the general public on every Sunday. There are 1200 metres of multigauge track (3,5", 5' and 7,25" ). Like our colleagues in Centurion, the members are the best guide to suppliers and sources of services, such as specialist foundries. Dennis (a member of RSME)
Edited By Dennis WA on 03/06/2022 14:09:25 Edited By Dennis WA on 03/06/2022 14:09:50 |
Thread: Minimum depth of cut possible with carbide tooling on S7 |
13/05/2022 20:33:20 |
Thank you all for taking the time to provide insightful feedback. It is clear that on a S7 the rigidity of the cutting tool mounting is critical. Then the selection of the appropriate insert. Then the selection of d.o.c., feed rate etc. In the past looking for good finish on my S7, I have followed the suggestions made. I found that it often does not work first time around in producing a good finish. So tweaking is required. Note that I have never tried to use a minimum d.o.c.. I found the comments on small d.o.c. interesting. Dennis |
12/05/2022 20:37:38 |
A fellow club member who has a Myford S7 wants know what is the minimum depth of cut he can use to get an excellent finish when using inserts on steel. He was aware of tables published, but I have not seen them. Can anyone enlighten us? Dennis |
Thread: Delay to Issue 299 |
04/12/2020 08:29:40 |
Pocketmags copy available! Thanks to Beth for keeping her promise. |
Thread: Rabone machine level |
28/04/2020 22:43:50 |
See also the 2017 thread by Andrew Tinsley https://www.model-engineer.co.uk/forums/postings.asp?th=129638
Thread: Stuart 9 building tips |
24/04/2020 17:45:48 |
Thanks Dave. Tubal Cain covered the build in 1975 (ME Vol 141) which became the book. I now have a bound copy of Vol 141. It seems there were no other posts highlighting errors or construction tips. Dennis |
23/04/2020 10:22:11 |
I am about to start building a 9H. The complete set of castings etc came from a deceased estate and includes the pump and governor, plus drawings. Searching Bill Phillips and Chris Orchard's ME index and this site has not turned up any construction notes or observations. Are there any that I have missed? Thanks Dennis |
Thread: Percival Marshall Speaks - Model Engineering Video |
14/04/2020 14:14:26 |
DC31k writes above: There is another thread on here mentioning an article on Schlesinger limits by a South African guy which can no longer be found (I believe it was somewhat turned into an article for MEW). If this were also located again, it would be good to host it. The article is : "No limits: George Schlesinger" by Alan Bester. MEW No 246. Autumn 2016 |
Thread: Colchester Student Mk1 Won't Start |
09/04/2020 10:07:02 |
Richard I used a piece of coated steel approximately 150x80x1.6 mm that was to hand. Dennis |
08/04/2020 22:34:09 |
Duplicate post removed Edited By Dennis WA on 08/04/2020 22:36:40 |
08/04/2020 22:32:34 |
Richard, I am sure you have thought about this, but do not get paint on any surface of the gap bed that sits on, or is adjacent to, the main lathe bed. To preserve the accuracy of the machine when reinstalling the gap bed it must be clean and go in the exact same position. My Student stands on a concrete floor with some shim under one corner to get it firm and level. I have no problems with accuracy of the finished product. If you want to raise your student you could use heavy steel channel across each end. My Myford Super 7 ( which is on a factory steel cabinet with tray) is raised like this. I also have no problems with its accuracy. I have a high precision level which helped to ensure the lathe beds were not twisted. I machined test bars to confirm the lathes cut the same dimension near the chuck and at the end of the bars near the tailstock. Good to see you are able to use the Student. Dennis |
Thread: Help with Capstan Crankshaft Deflection Indicator |
08/04/2020 15:11:02 |
Howard The grub screw provides an adjustable stop for the gear quadrant that meshes with the pinion on the shaft carrying the pointer. Conclusion: There is no provision for zeroing the pointer with the dial. I opened the movement after removing the bezel using a sharp blade. It needed a clean and I reset the pointer to rest at +20 and it now goes round to -25 without difficulty. More than enough range for me to check the deflection of crankshaft webs, which indicates a shaft running out of true. Problem solved! Dennis |
08/04/2020 12:46:00 |
Thanks Howard Slacking the grub screw was the first thing I tried. No effect. I could not unscrew it from the body either. I will try and see if the bezel is seized on the body preventing rotation. Dennis |
08/04/2020 12:31:42 |
Bazyle Thanks for the comments. I have watch and clock tools and repair experience. I cannot get the bezel off without resorting to force, which is not an option! Dennis |
08/04/2020 12:26:07 |
Thanks Ady My problem is that I cannot rotate the dial. How does one do this so as to set the pointer where you want it? There is a screw in the body, but I have not been able to work out what it does. Dennis |
08/04/2020 10:58:25 |
Richard...Phil has done a great job in helping you, including emphasing the safety aspects. I agree with Dave that you have sorted it out as you have progressed and are learning as you go. I have a 1964 Student Mk 1.5 and have followed the thread with great interest. At no stage could I add anything to what you had got from other folk. Congratulations on your progress - enjoy using the Student and good luck with your studies. Dennis |
08/04/2020 10:32:32 |
Is it possible to turn the dial so that the reading covers the positive and negative movement equally? The picture below shows what I want. The picture with the yellow arrows shows what I have : an anti-clockwise movement from rest position at -18 to full deflection at -5. Thanks Dennis Edited By Dennis WA on 08/04/2020 10:36:01 |
Thread: TTFN |
19/07/2019 20:02:51 |
Andrew I am really pleased that you are going to take a short break and then rejoin us! All the best Dennis |
18/07/2019 15:30:34 |
Sadly your withdrawal harms the benefit that most of us derive from this forum. It only benefits those who believe they can ignore good manners when expressing their opinion. Edited By Dennis WA on 18/07/2019 15:32:42 Edited By Dennis WA on 18/07/2019 15:33:53 |
Thread: Digital display settings changed and not sure how to get it back! |
28/04/2019 07:53:11 |
Contact Machine-DRO at:
I have their product on my lathe and milling machine and have found them most helpful. They advertise on this page - see the ads under Support Our Partners on the right hand side. You can go directly to their webpage at www.machine-dro.co.uk
