Ian Roberts 1 | 14/05/2016 18:57:59 |
4 forum posts | Hi i am Ian .I am aclock restorer with an md65 hobbymat lathe as well as a watchmakers lathe .My problem is that one relay has burn out on the MD 65 does anyone know where to get a replacement .They are blue and about 1.250 square and about .625 thick. I believe they are double poll double throw . My knowledge of electronics is very limited so any help and advice would be appreciated . |
Michael Gilligan | 14/05/2016 20:08:36 |
![]() 23121 forum posts 1360 photos | Ian, First ... Welcome Aboard !! Now: You might find this recent thread of interest MichaelG. |
John Rudd | 14/05/2016 20:09:55 |
1479 forum posts 1 photos | Ian, Pictures of the offending item might help identify the relay especially if it has any numbers printed on it.... |
Ian Roberts 1 | 15/05/2016 12:06:16 |
4 forum posts | Ian Roberts 1.Thank you for your kind replies I have seen the thread and tried it with no luck .The relay has printed on it GBR 40 1-11.240 The coil in the relay is OK but the contacts above have melted. Sorry can't send photo haven't a clue how |
Martin W | 15/05/2016 13:12:43 |
940 forum posts 30 photos | Hi Ian There is a description of 40 series relays that have a similar numbering system here. It may be a point to start to see if you can identify the correct unit. A good source of components that I use is CPC which come under the Farnell group. Hope this helps. Martin Edit: Do you know why the contacts have melted, is it down to old age or something more serious? Edited By Martin W on 15/05/2016 13:14:21 |
Ian Roberts 1 | 16/05/2016 11:11:15 |
4 forum posts | Hi. Thanks Martin |
Ian Roberts 1 | 16/05/2016 11:20:31 |
4 forum posts | Hi . Thanks Martin for the information about the relays.I will try and get some from where you suggested.If they work. I shall let anyone else with an md65 know what they are. As to why they melted it is probably old age as I bought it in1990 never had a problem till now. One or two of my bits and pieces are in much the same state. ian |
