Short morse taper drill bits.
Mark P.14/04/2016 19:49:38
634 forum posts
9 photos
Does anyone know if short (1/2 length)MT2 drill bits are available?
Regards Mark P.
John Stevenson14/04/2016 21:16:49
5068 forum posts
Certainly. When they are half worn out..................
HOWARDT14/04/2016 23:19:07
1081 forum posts
39 photos
We used to use split morse taper holders with tangled drill of the required length. Expensive as tang sizes change as drill sizes increase so require a number of sleeves. Cheaper to use collet holder or simple chuck.
Chris Evans 615/04/2016 07:35:49
2156 forum posts
I tend to use a cut off wheel and shorten well used ones. It is usually the first couple of inches of flute that is worn.
If I am only "rough" drilling I will sometimes grind the drill a bit one sided to cut slightly over when the flutes are showing wear, tends to stop the rubbing.
Mark P.15/04/2016 08:54:41
634 forum posts
9 photos
Thanks chaps might go looking for old ones at autojumbles etc and cut them down.
Mark P.
