Mark P. | 29/03/2016 17:33:16 |
![]() 634 forum posts 9 photos | Hi all, I need to make 2 pices of mild steel channel 44x25x4x300mm long if I machine it from 25x50mm bright flat will I end up with a twisted mess? Regards Mark P. |
Michael Gilligan | 29/03/2016 17:37:14 |
![]() 23121 forum posts 1360 photos | Very probably. I think it would need some Stress-Relief first ... a night in the embers of a fire might help. MichaelG. |
JasonB | 29/03/2016 17:37:59 |
![]() 25215 forum posts 3105 photos 1 articles | Cut down two bits of angle and weld them into a U. If you like making swarf then get black flat bar as its less likely to move. I have used this e-bay seller a few times for black bar and angle, also does 50x25x5 chanel if you could get away with 48mm x 24 x 4 after a skim Edited By JasonB on 29/03/2016 17:42:12 |
Mark P. | 29/03/2016 18:41:09 |
![]() 634 forum posts 9 photos | Thanks for the replies just as I thought a mangled mess! Will have a look at that supplier Jason. If all fails I will try black bar. Regards Mark P. |
