Dave Powell 2 | 13/03/2016 18:37:43 |
33 forum posts 11 photos | Hi folks, I stupidly managed to break my gauge glass during a boiler test yesterday and am struggling to find a replacement. It's 7mm diameter, it had a thin red line down it which made it really easy to see the water level. All the usual suppliers only seem to do the clear stuff. Anybody know where I can get some? Thanks in advance.
OldMetaller | 13/03/2016 19:01:03 |
![]() 208 forum posts 25 photos | Hi Dave, Live Steam Models- http://www.livesteammodels.co.uk/ - have what you want on p. 35 of their supplies catalogue. Regards, John. |
Steamer1915 | 13/03/2016 19:05:34 |
![]() 171 forum posts 42 photos | Hi Dave, You could always try:- Barry Boyce Best regards, Steve. |
mick H | 13/03/2016 20:30:07 |
795 forum posts 34 photos | Polly Model Engineering 0115 9736700 stock 7mm red line.
julian atkins | 13/03/2016 21:51:17 |
![]() 1285 forum posts 353 photos | hi dave, schellbach gauge glass is more brittle. can i suggest you carefully check alignment of the top and bottom fittings. also dont let the bottom end of the glass touch the recess in the bottom fitting. cheers, julian |
Dave Powell 2 | 15/03/2016 08:27:51 |
33 forum posts 11 photos | Thank you for your replies, Gentlemen. I had looked at the Polly catalogue but did not find it in there. I will give them a ring today and get some in. The reason the last one broke is that at full heat the drain cock went really tight. On trying to open it the bottom fitting turned and cracked the glass. I think I am very lucky that disaster did not ensue. We aborted the steam test at that point and I came home rather sadder than I was an hour previously, when it had passed it's hydraulic test. Oh well, that's life
