Silicone sealant WITHOUT acetic acid
Jeff Dayman04/03/2016 17:01:49
2356 forum posts
47 photos
Several people have reported problems with corrosion as a result of using silicone sealant in small Stirling cycle engines.
The common RTV silicones do use acetic acid as part of their curing method.
This has been a problem in electronics assys for some time, with the acid corroding conductors and leadwires, and as a result the silicone companies developed "neutral cure" or "electronics grade" RTV sealant with no acetic acid cure.
I am not sure about availability in the UK but in North America it was marketed as Dow 737 neutral cure RTV sealant.
Maybe Radio Spares or Farnells carry it in UK. Digikey and Sayal Electronics both carry it in USA and Canada.
Good luck JD
Bazyle04/03/2016 18:09:22
6956 forum posts
229 photos
Glaziers will sell you a more expensive 'rubberised' goo for sealed double glazing which I think is acid free. Used because some panels use metal spacers round the edge.
Steve Skelton 104/03/2016 18:29:34
152 forum posts
6 photos
What you need is low modulus silicone. This is not the acetoxy high modulus type. It does take longer to cure but generally has better adhesive properties.
If you want mail order (or have a local outlet) try "Toolstation" product code 85598
Cheers
john swift 104/03/2016 18:42:41
318 forum posts
183 photos
used this to reseal an alternator regulator after I replaced a faulty transistor -
Jonathan Mead04/03/2016 23:01:48
30 forum posts
12 photos
Silicone sealants are either 'acetoxy cure' or 'neutral cure'. These are the key phrases to look out for when purchasing. To avoid the corrosion problems, use a neutral cure sealant. Screwfix and Toolstation sell neutral cure sealants.
Ajohnw05/03/2016 13:00:17
3631 forum posts
160 photos
When I went into a local builders merchant and asked for clear silicone they were one of the few that asked if I wanted the sealer or the adhesive versions. So depending on what will be done with it that may be worth bearing in mind. The glue types will give of acetic acid as they cure.
Taken over by a chain now so the person behind the counter probably wont have a clue. Moan over. There were a lot of smaller companies supply various trades round here and they are steadily disappearing.
