Feedscrew Material
James B03/03/2016 08:41:14
101 forum posts
14 photos
Hi All,
I am currently rebuilding an old drill grinder, and am considering remaking the feedscrews / nuts as these are quite worn.
I wonder if anyone has experience of this, with regard to material selection? Would EN1 be adequate, or should you go for a higher grade steel? The nuts are bronze, and the thread is 5/8 x 20 TPI (which seems to be cycle thread - these are for fine feed).
Thanks,
James
Howard Lewis03/03/2016 16:45:22
7227 forum posts
21 photos
I thought that all cycle threads were 60 degree x 26 tpi.
20 tpi is a nice convenient thread for a feedscrew, since it gives 0.050"/rev. Sometimes, I use 1/2 UNF , since it is 20 tpi, for that very reason.
Nigel McBurney 103/03/2016 18:03:21
1101 forum posts
Machinerys screw thread book lists British cycle threads Tpi Ranges from 24 tpi (hub sprockets etc) to 56 (small spokes) most common usage is 26 tpi (nuts and bolts etc) 20 tpi is not on the list.Some may frown but I have used EN 1A leaded for feed screws,excellent finish ,and they last a long time in association with bronze nuts, though a they will not last so long on a drill grinder unless the screw is shielded from the grinding dust
Chris Evans 603/03/2016 21:43:21
2156 forum posts
BSCY is 26/20/and 24 TPI 60 degree angle. Things like wheel spindles on pre war bikes are 20 TPI in either 1/2" or 5/8" I sometimes have to use UNF if the correct BSCY tap is not available.
John Reese04/03/2016 02:33:22
1071 forum posts
I don't know the Brit steel classifications so I will be using US terminology. My preferred material for making lead screws would be 1144. It is a resulfurized steel of .44 nominal carbon content. It machines beautifully. Sometimes it is sold under the trade name Stressproof. Tensile strength is considerably greater than mild steel.
John Haine04/03/2016 13:34:57
5563 forum posts
322 photos
I would have thought that the threads on a drill grinder would not have heavy loads or wear quickly. I'd suggest using good quality stainless studding, say M6x1 mm, and tapping brass or bronze nuts to fit.
James B10/03/2016 10:32:00
101 forum posts
14 photos
Hi All,
Thanks for your posts - sorry for delay in replying.
Some more digging has revealed these are 5/8 x 20 TPI threads, BSW form - I had previously found some 5/8x20 cycle taps listed on RDGs site, which is why I had assumed they were cycle thread.
I want to keep the machine as original as possible, so I don't really want to use studding on this occasion - but a good idea for a future project.
I had been thinking of EN1, but want these to last - I couldn't find a UK equivalent to 1144, but EN8 looks to have a similar carbon content, so I have ordered a length on EN8, and will see how I get on.
Thanks again,
James
Neil Wyatt10/03/2016 14:37:43
19226 forum posts
749 photos
86 articles
EN8 is a good choice.
