TREVOR WILSON | 24/02/2016 09:30:37 |
9 forum posts 7 photos | Can anyone please offer any help or advice! My aging Warco Major Mill (1992 vintage) appears to have developed a bearing problem within the spindle head, it has become very stiff and notchy to turn. I would appreciate any guidance/advice on how to strip the head down with view to replacing the bearings - not keen to charge in and risk causing more problems than I already have! |
John Rudd | 24/02/2016 11:07:31 |
1479 forum posts 1 photos | Grizzly manual here showing assembly drawings in section9 http://cdn0.grizzly.com/manuals/g0705_m.pdf |
Robbo | 24/02/2016 16:57:21 |
1504 forum posts 142 photos | Trevor, Will provide more info later, but most important note that the lock nuts holding the spindle in the quill are Left Hand thread! |
MW | 24/02/2016 19:33:14 |
![]() 2052 forum posts 56 photos | I would contact warco themselves as they are still selling this model and would probably be helpful. Michael W |
TREVOR WILSON | 25/02/2016 07:37:04 |
9 forum posts 7 photos | Thanks to all of you for your help, especially concerning the left hand thread!. I will now feel happy about dismantling the beast. |
Robbo | 25/02/2016 14:47:24 |
1504 forum posts 142 photos | Trevor, I have added a new album (in my "Albums" - ho ho!) called "Warco Major Parts List". This has a drawing of the quill/spindle area of the head, plus the 5 pages of parts numbers to go with the drawings. I find this drawing easier on the eye than the exploded type. (It is an "official" Warco drawing) You may of course already have a Warco manual containing this, but it may be of interest to others if that is the case. If you don't know, just click on "69 photos" on the left of the posting to get into the albums. There was a 3-part article in MEW last year called "Rebuilding a Warco Major Mill/Drill", but it was mainly concerned with changing the motor and drive/speed control completely rather than rebuilding to original spec. That's where I found out about the left-hand thread. I'll have a look at it and see if any parts of it are relevant to your job, and message you if so. Edited By Robbo on 25/02/2016 14:48:49 Edited By Robbo on 25/02/2016 14:50:27 |
ega | 25/02/2016 15:31:39 |
2805 forum posts 219 photos | Robbo: The drawing was indeed of interest to me as it looked very similar to my ancient Warco Economy Mill/Drill (which came without a manual). I was not surprised that I could not find the corresponding drawing for my machine on their website and I wonder where you found the one you put in your album? One useful piece of information from Warco is that their Super Major Mill comes with a "Pedant Control" switch! |
Robbo | 25/02/2016 18:50:54 |
1504 forum posts 142 photos | ega, The Warco drawings apply equally to all three of the Major, Minor, and Economy models. The design/structure is similar, just the size of some components differs. The drawing came from an old Warco manual, written in the usual Chinglese, so as an operating manual it's not much help, but the drawings are good. If you want a copy then message me your email address and I'll do one as a pdf file. Can't put pdf on the albums, only jpeg. I noticed the "Pedant Control" on the Super Major, so that model is no use to me - I refuse to be controlled by a switch! |
ega | 25/02/2016 23:30:02 |
2805 forum posts 219 photos | Robbo: Thank you - I'll PM you. |
TREVOR WILSON | 26/02/2016 08:09:35 |
9 forum posts 7 photos | Robbo Thanks very much for the drawing/parts list - I have now started the strip down!. |
Mike Ridge | 14/06/2016 04:35:16 |
7 forum posts |
Hi Robbo or Trevor , I would much appreciate any help you can give me ,, I have the Warco economy , which I believe the head quill is the same as the Major models ( I looked at Robbo drawings ) .. It's getting Hot around the bottom of the quill area ,, I think that the bearing is causing the problem ,number 45 on your drawings , looks like a taper bearing ,, has Trevor got any best procedure for stripping it down , I had just read he may be starting it ,, or if anyone has any tips on tackling the changing of the bearings on this machine I'd like to hear from them the best way to tackle it . Thanks Mike
Robbo | 14/06/2016 09:46:25 |
1504 forum posts 142 photos | Mike, You are correct, the upper and lower bearings are roller taper, No 30207, readily available. I've never had to dismantle mine, as although 20 + yrs old it was previously owned by an ex-toolmaker who used it for building locos, and was carefully used. (The mill not the toolmaker) The full manual that I sent to ega might be useful to you, if you PM me with your email address I'll send a copy. I'll have a look at the MEW I mentioned previously and see if there is any dismantling tips. |
Mike Ridge | 14/06/2016 14:02:28 |
7 forum posts | thanks Robbo , and appreciate the help /info,,,i like the machine ,I believe it has stood idle for many years ,so if not serviced on the start up it is possible a bearing could fail , I intend to change them , keep you updated , cheers mike if anyone on the site does have any more experience on these machines / info ,,let me know cheers , |
TREVOR WILSON | 18/06/2016 08:40:00 |
9 forum posts 7 photos | Mike, the spindle runs between 2 taper roller bearings as Robbo said but on the Major the bearings are different sizes - 30207J2 and 30206J2. Both of these I obtained from Brammer. They also supplied the lower seal part No NBR45X72X8A. Total cost was approx. £65. The rebuild was straight forward, just remember the 2 locking nuts to set the shaft endfloat are left handed!!. Regards Trevor |
Neil Wyatt | 18/06/2016 09:53:03 |
![]() 19226 forum posts 749 photos 86 articles | Posted by ega on 25/02/2016 15:31:39:
One useful piece of information from Warco is that their Super Major Mill comes with a "Pedant Control" switch! Excellent, I wonder if they sell them as an off the shelf spare Neil |
Neil Wyatt | 18/06/2016 09:55:18 |
![]() 19226 forum posts 749 photos 86 articles | Posted by TREVOR WILSON on 18/06/2016 08:40:00:
Mike, the spindle runs between 2 taper roller bearings as Robbo said but on the Major the bearings are different sizes - 30207J2 and 30206J2. Both of these I obtained from Brammer. They also supplied the lower seal part No NBR45X72X8A. Total cost was approx. £65. The rebuild was straight forward, just remember the 2 locking nuts to set the shaft endfloat are left handed!!. Might be worth trying Arc Euro first, they list 30207 at £15.50 inc vat and 30206 at £9.26 which will save you a few coppers. Neil Edited By Neil Wyatt on 18/06/2016 09:56:11 |
Robbo | 18/06/2016 09:58:44 |
1504 forum posts 142 photos | Thanks for that useful info Trevor. In my parts list they are both shown with the same number. Parts list will be annotated with the difference, thanks |
Mike Ridge | 21/06/2016 17:55:38 |
7 forum posts | Hi Trev,Robbo, Neil, I know this seems like its turning into a pain , I have replaced the bearings top and bottom packed them with top quality grease ,,the bearing are actually a 30206 and a 30205 the lower seal is vc 38--62 ,and you wouldn't believe it the problem is still there ,,that bottom area around the quill is still getting hot after 5 minutes ,,I thought I had sorted it installing the new skf bearings, it wasn't a bad job .and ive taken off preload and set it again ,,but it still runs hot ,you can feel the temperature with your finger on the outer of the quill and in the 3 morse taper up the middle ,,the top bearing is fine . don't know what to do now ,as im writing this ,im at a bit of a loss what to do mike |
not done it yet | 21/06/2016 20:57:51 |
7517 forum posts 20 photos | Is it getting hot due to too much grease? Add oil, then allow it to leak out? |
Mike Ridge | 22/06/2016 05:56:07 |
7 forum posts | That was an idea, but before I decided to do the bearing change ,I flooded it with wd40 ,and pushed oil through from the can , still warmed up What I was thinking , going to make enquiries if I can get a sealed pre loaded bearing the same size |
