Bill Pudney | 25/01/2016 02:39:29 |
622 forum posts 24 photos | Hopefully this is a fairly easy one, once the answer is known!! I have a Sieg C3 mini lathe. I was turning some al.alloy this a.m., everything was going well until it stalled. This is not particularly unusual, but not a frequent occurrence. I turned the speed control back to zero, turned the Forward/Off/Reverse switch to "Off", then back to "Forward", this usually resets everything. Turned up the speed control and nothing happened. First thought was the fuse, checked that, it seemed o.k., but it was changed anyway. Went through the start up procedure, nothing. Tried it in reverse and it worked! That is the spindle turned in reverse. So I took the control box off, having unplugged the machine, there were no signs of any burned out components, no smell of escaping smoke. It all looked fine. Reassembled everything and tried again, and again it would only run in reverse. The spindle is free to rotate in both directions. Does anyone out there who has experienced this sort of thing, or has any idea what is going on?? cheers Bill |
john carruthers | 25/01/2016 07:53:22 |
![]() 617 forum posts 180 photos | Does your F/R switch have a rubber gaiter? If not swarf sometimes works into the switch and shorts it.
Danny M2Z | 25/01/2016 07:54:35 |
![]() 963 forum posts 2 photos | Hi Bill. Could the Forward/Off/Reverse switch have crapped itself? Easily checked with a multi-meter. Disconnect power from the lathe first. * Danny M * |
john swift 1 | 25/01/2016 10:28:54 |
![]() 318 forum posts 183 photos | Hi Bill since it only runs in reverse it looks like you need a new switch on my CL300 lathe I found the push on connectors connecting the motor to the switch didn't make a very good connection again once they have been removed
Edited By john swift 1 on 25/01/2016 10:53:00 |
ega | 25/01/2016 11:19:18 |
2805 forum posts 219 photos | Might it be possible as a temporary workaround to rewire the switch so that reverse gives forward? |
Les Jones 1 | 25/01/2016 14:46:21 |
2292 forum posts 159 photos | Hi Bill, Les. |
