richard 2 | 09/11/2015 09:07:52 |
127 forum posts | Hi I see several threads about cleaning a 3-jaw but how about dismantling, cleaning and putting together a Griptru? Am about to guy a second as I think they are excellent. I note that some people say a 4-jaw independent is better, but, if so, how do I hold hexagon rod in it? Any info on the Griptru would be welcome. Many thanks Richard. |
Brian Wood | 09/11/2015 09:31:28 |
2742 forum posts 39 photos | Hello Richard, It is little different to cleaning a standard three jaw chuck really. The added features of the individual cones that make the micro adjustments to individual jaw setting take quite a lot of patience to get right afterwards. Ideally you need a good test bar gripped in the jaws for the work along with a DTI but a reliable piece of silver steel will do instead.Use the hex key on the cross bar of the chuck key to make those adjustments, checking by DTI close to and 2 or 3 inches away from the chuck before nipping up the backplate bolts. Then check again and repeat if things have moved The chuck should hold those settings for that diameter for a long time afterwards. Light oil is the correct lubricant Regards Brian |
Ajohnw | 09/11/2015 09:37:59 |
3631 forum posts 160 photos | A few posts down below this one John - |
Steve Pavey | 09/11/2015 12:32:32 |
369 forum posts 41 photos | I've never had the need to, but it is possible to hold hex bar in a four jaw chuck. Using an indicator to true it up might be a bit of a challenge? A four jaw self-centreing chuck will hold it on centre though - I think it was mentioned in one of Dan Gelbart's Youtube videos. |
Gordon W | 09/11/2015 14:45:10 |
2011 forum posts | Easiest way to hold square bar in 3 jaw is to make a bush- turn o/s to round, drill to the across corner dim. and split with hacksaw. The sizes depend on what you need but would have wall thickness min. 3mm. Rub a file over the corners of the bar. This is not super accurate but works. |
NJH | 09/11/2015 21:15:19 |
![]() 2314 forum posts 139 photos | Richard Check your in box - I have sent you a pm Norman
