Hot Lacquering Brass
Garry Walton01/09/2015 11:15:09
1 forum posts
Approximately 40 years ago I worked in a small company (as a young boy!) that built and repaired balances for the scientific community and precious metals industry. The brass components were often hot lacquered which resulted in warm dark finish. I am now interested in restoring some early assay balances and would like to use hot lacquering. Despite searching the internet I have not found any details of this process. Has anybody experience or knowledge of hot lacquering. I recall the person who did it used a spirit burner (clean gentle flame) and a solution which I assume contained shellac?
Thank You
Garry
john carruthers01/09/2015 13:26:41
617 forum posts
180 photos
I don't know the traditional method but I recently re-finished a brass microscope and have done telescope parts in the past. Indian shellac, alcohol and a little curry powder (for colour) 5% shellac, 95% alcohol, colour to taste. Blend well in a jar with a few marbles run it through a filter paper, then dip or spray the piece. Then using either a strong hair dryer or hot air gun warm the piece evenly to drive off the volatiles, you can watch the colour change gradually, it also gives a more even coating.
Edited By john carruthers on 01/09/2015 13:28:07
Clive Hartland01/09/2015 14:44:30
2929 forum posts
41 photos
I think the mixture you are looking for is, 'Dragons Blood'. If you search for that you may find what the mixture is.
Hot laquaring is easy to do by gently warming the part and then using a Sable brush go all over and do not go back on a stroke. The curry powder mix sounds a bit sensational.
PS. see Google as it is well described and also Wicki.
Edited By Clive Hartland on 01/09/2015 14:46:33
Ajohnw01/09/2015 18:00:03
3631 forum posts
160 photos
I thought that Nitrocellulose lacquers were used from around 1920 or so. It did get rather thin on the ground but does seem to be around again. I believe heat is sometime used with it but I think it's more associated with drying. The problem was probably that it's one step away from explosives.
I have seen mention of shellac based with a mix of things like turmeric being used. Eg this one
There are also epoxy type things around that are mostly used on musical instruments
I have a slight interest in restoring a brass microscope. Looking around nitrocellulose seems to be used most often but if pre circa 1920 that probably isn't authentic.
Clive Hartland01/09/2015 21:29:25
2929 forum posts
41 photos
I do remember using a product called, 'Frigiline', Again I think it was cellulose based and dried to a clear coating but was told that it could be coloured by a pigment thus becoming , 'Dragons Blood' , The colour of this varnish enhances the brass tubes of old instruments. The last Company that I know used this method was, Cambridge Instruments, but that was before the late 60's. Enquiries to people who worked there told that it was no longer used.
I long sought this item but gave up trying, I see that 50gms of pigment cost about £30. The art is now lost and modern finishes have taken over.
