How to protect tube ends during stay soldering
David Haynes | 28/08/2015 21:30:51 |
168 forum posts 26 photos | I want to solder firebox side stays but don't want to damage the existing solder on the tube ends less than 1/2" away. I had thought of using a bit of squashed down soldering blanket but wondered what other folks use. Thanks, Dave |
Michael Gilligan | 28/08/2015 21:39:57 |
![]() 23121 forum posts 1360 photos | I have found Cool Heat paste very effective on small assemblies. MichaelG. |
Neil Wyatt | 28/08/2015 22:27:09 |
![]() 19226 forum posts 749 photos 86 articles | Is that stuff really called what I think it is!?! N. |
Michael Gilligan | 28/08/2015 22:36:04 |
![]() 23121 forum posts 1360 photos | |
duncan webster | 28/08/2015 23:56:24 |
5307 forum posts 83 photos | You can get Ceramic Paper http://www.hightemperaturetextiles.com/needlemat-blanket-paper/refractory-and-ceramic-blanket-and-paper/ceramic-paper.html?gclid=CLWJmrrvzMcCFYYfwwodr6YH8w I scrounged a bit from a local furnace repair company for doing a very similar job |
Keith Hale | 29/08/2015 09:27:48 |
![]() 334 forum posts 1 photos | I assume you have initially used a low temperature silver solder eg 42% with cadmium or 55% cadmium free. The remelt temperature of both is higher than their original temperature. This is caused by the solder absorbing copper and changing its' composition. Do a simple test. Replicate 4 stays in a line. Braze them. Let them cool. Now set up a parallel line of stays 1/2 inch apart. Braze them with your low melting point silver solder. Use a suitable burner that will enable you to control the heat. Watching the flux will help you to avoid overheating. As soon as it goes clear your are at brazing temperature. Ensure you also cover the first line of joints with flux to protect them if you do remelt them Alternatively attach a heat sink where rfequired. This could be a damp rag, a mole grip wrench or apply Pyrocool - a spray product available from Advanced Engineering Ltd Redhill (no connection other than we used to sell it - demand not meeting expectations). Keith
