Windy | 25/08/2015 15:35:51 |
![]() 910 forum posts 197 photos | Having had some very useful advice before and we have members in the full size racing engine scene maybe someone can tell me where to find the following. I can find model engine and some 250cc twin engine sizes. I require sizes of full size dykes piston rings around 75mm to 80plus mm and who can I get them from in the UK. Some of the top dragsters cars use them. Paul Edited By Windy on 25/08/2015 15:36:29 |
Clive Hartland | 25/08/2015 17:49:20 |
![]() 2929 forum posts 41 photos | TMUK, It seems Google throws up several suppliers in the UK and some suppliers in the USA. Clive |
Neil Wyatt | 25/08/2015 18:31:11 |
![]() 19226 forum posts 749 photos 86 articles | Oh dear. He's serious about this supersonic steam bike... I hope Paul's got double-strength bicycle clips. Neil |
Windy | 26/08/2015 15:35:30 |
![]() 910 forum posts 197 photos | There is another ring used on dragsters that I'm considering it utilizes holes in the piston top that use pressure on back of ring to push it on the cylinder might try that on the model. Not normally used on petrol engines because of carbon that might block the holes. Just had an invite by a past acquaintance from the bike days to his CNC machine shop to see what he is doing. After seeing the quality of his work and his involvement with the following to be driven by James Toseland I'm drooling as an amateur machine knob twiddler.. Edited By Windy on 26/08/2015 15:37:51 |
Neil Wyatt | 26/08/2015 15:53:58 |
![]() 19226 forum posts 749 photos 86 articles | If he's OK with it, write me a short 'workshop report' for the mag! Neil |
Gordon W | 26/08/2015 16:38:08 |
2011 forum posts | Windy-that looks rather like a record breaker from way past. Built like a space frame, VW flat four moter. It was very advanced for the time, stress gauges etc. The length and positioning of components and rider caculated to reduce tyre spin and front lift. Then he shortened it a lot so that it would fit in the van. |
Brian Wood | 26/08/2015 20:24:21 |
2742 forum posts 39 photos | Windy, Would you know of Graham Sykes [Sykes Engineering] up here in North Yorkshire at Scotch Corner? He is into serious speed racing on two wheels with serious power plant to hurl him down the track. A recent record holder of some kind I vaguely recall. Nice man and a seriously good workshop where they do really fancy stuff Brian |
Windy | 26/08/2015 20:45:12 |
![]() 910 forum posts 197 photos | Posted by Brian Wood on 26/08/2015 20:24:21:
Windy, Would you know of Graham Sykes [Sykes Engineering] up here in North Yorkshire at Scotch Corner? He is into serious speed racing on two wheels with serious power plant to hurl him down the track. A recent record holder of some kind I vaguely recall. Nice man and a seriously good workshop where they do really fancy stuff Brian That's the man a real enthusiast was talking to him a few weeks ago at Elvington speed attempts. The streamliner is a gas turbine wheel driven it's creator Alex was part of the Don Vesco team. http://www.teamvesco.com/vesco111.html Gordon this is the VW machine I saw this machine many times.
Edited By Windy on 26/08/2015 21:00:57 |
Gordon W | 27/08/2015 09:36:05 |
2011 forum posts | Windy-that's the one, no mention of the technical shortening to fit in the van!. Brings back memories, Alf Hagon, of damper fame and grass track, that was a serious machine- V twin Jap in a speedway frame. No clutch as I remember, just dropped the back wheel on the ground at the right revs. |
Howard Lewis | 28/08/2015 21:47:42 |
7227 forum posts 21 photos | Dykes rings are a really venerable design. Modern materials and processes should make them perform even better than when they were first invented. Before I retired nearly twelve years ago, it had been common practice to have compression rings narrower than the groove depth so that they were gas backed. We found that the ring gap had a big effect on blowby.. The secret was to have a cold fitted gap so small that, when hot (full load rated speed coditions) the ring ends did not butt together. If they did, you were certain to have bore damage and broken rings. The blowby tended to improve as the engine bedded in, as the rings lapped themselves to the faces of the groove. Quite a contrast to have a three ring pack that performed much better than the five ring packs of the sixties and seventies, in terms of both blow by and oil control. The better technology , based on experiences, made that possible. Some "new" things actually ARE better, not just in the minds of the marketing men. Howard |
Windy | 28/08/2015 23:58:45 |
![]() 910 forum posts 197 photos | Posted by Howard Lewis on 28/08/2015 21:47:42:
Dykes rings are a really venerable design. Modern materials and processes should make them perform even better than when they were first invented. Before I retired nearly twelve years ago, it had been common practice to have compression rings narrower than the groove depth so that they were gas backed. We found that the ring gap had a big effect on blowby.. The secret was to have a cold fitted gap so small that, when hot (full load rated speed coditions) the ring ends did not butt together. If they did, you were certain to have bore damage and broken rings. The blowby tended to improve as the engine bedded in, as the rings lapped themselves to the faces of the groove. Howard What you say is very similar to my model flash steamer Dykes ring setup and has been successful combined with 2014 and 2015 piston modifications. Paul
Andrew Johnston | 29/08/2015 11:55:24 |
![]() 7061 forum posts 719 photos | Paul Dykes was listed as a fellow of college when I matriculated in 1980. However, since he retired from the university engineering department, and as director of studies for engineering in college, in the early 1970s I never got to meet him. I've just re-read his obituary, having dug out the relevant college report. Apparently he started his piston ring research in 1947, sponsored by the motor industry. Andrew |
