Replacing a coolant pump.
Bob Rodgerson | 09/07/2015 15:28:59 |
612 forum posts 174 photos | I purchased a new coolant pump foor my manual milling machine because the old one went mental and blew up a few weeks back.
Today I got the new pump which is obviously a generic Chineese/Tiwaneese make because it fits directly onto the tank I have, using the same hole spacing and it is physically the same size and shape as the old one. I thought that it would have a nice simple terminal block with obvious positions for live Neutral and Earth wires however it doesn't. Here is a picture of the wiring facing me when I took the terminal cover off. There are six holes numbered 1-6 in the back of the terminal box. No.s 1 & 3 are both red wires that have a crimped terminal on their ends. N's 2 & 5 wires are both white and are crimped to the two wires that come from the Capacitor. I presume that it doesn't matter which of the two red wires with the crimped terminals are connected to, either live or neutral and also I presume that the earth wire is terminated under one of the screw heads that holds the terminal box to the pump motor body. I am of the firm belief that wire is used as a conduit for smoke and other than that have no idea how it all works but would appreciate some help prior to blowing myself up. |
Stuart Bridger | 10/07/2015 08:37:56 |
566 forum posts 31 photos | My first suggestion would be to contact the vendor for wiring instructions. You presumption is most likely correct though, but if any doubt I would recommend contacting a qualified electrician to check it over. Given that there are six wires, I suspect that it is a 3 phase induction motor, with a motor run capacitor for the 3rd phase, but no guarantees.
Bob Rodgerson | 10/07/2015 09:08:23 |
612 forum posts 174 photos | Hi Stuart, I'm sure your assumption is correct. As I see it swapping the two red wires around will only change direction of rotation and on this type of pump with straight impeller blades makes no difference to the pump output. |
Les Jones 1 | 10/07/2015 09:29:01 |
2292 forum posts 159 photos | Hi Bob, Les. |
Bob Rodgerson | 10/07/2015 10:04:29 |
Hi Les here is another picture and as you can see both the white wires are connected to the capacitor. It is not too clear which wires go where even from this picture, it looks like two red wires are joined at the crimp connection to the right but this is not the case there are definitely a white from the motor and red wire from the capacitor joined together at these connections. Bob |
Bob Rodgerson | 10/07/2015 10:06:19 |
612 forum posts 174 photos | Les, I forgot to add, the thick white wire on the photo's is some 3 core power cable from the original pump. |
John Rudd | 10/07/2015 11:02:23 |
1479 forum posts 1 photos | To avoid any confusion here, There are two RED wires with ring lugs attached......yes? There are two WHITE wires each crimped/joined to the two RED wire coming from the capacitor yes?
There are no more wires coming from the pump unit yes ? A standard configuration for a permanent cap motor.....
In that case the mains L/N goes to the two RED wires with the ring lugs and Earth- green yellow to the metal casing......
Could I ask where you got the pump from ? I'm thinking of adding a coolant system to my new lathe....
Edited Edited Edited By John Rudd on 10/07/2015 11:09:23 Edited By John Rudd on 10/07/2015 11:10:26 |
Bob Rodgerson | 10/07/2015 13:04:18 |
612 forum posts 174 photos | John, Correct. If that is the case then all is as I thought. I got the pump from RDG after the motor on my portable coolant system that I use on the manual mill blew the capacitor. It is identical to the new unit. It blew the capacitor and I couldn't decifer what capacitance and type of capacitor was required. The wiring was fried too so I'm not too sure if it would still work if a new capacitor were fitted. I suppose the new pump capacitor will have details so that I can determine what is required. If you want the broken pump I can send it to you along with those details for the cost of postage. If it works it's a bonus if not its just a few quids worth of speculation. Regards, Bob. P.S. let me know if you are interested. |
John Rudd | 10/07/2015 13:49:08 |
1479 forum posts 1 photos | Bob,
You have a private message ......
cheers
John |
Les Jones 1 | 10/07/2015 14:11:09 |
Bob Rodgerson | 10/07/2015 14:50:37 |
612 forum posts 174 photos | Thanks les. John. I have responded to your message. I will wire in the pump tonight and let you all know how it goes. |
