Simon Collier | 14/06/2015 01:15:53 |
![]() 525 forum posts 65 photos | I am sorting out a newly acquired ML7, 1964 vintage. I wanted to check that the tailstock was accurately on zero set over but it was immediately obvious that the adjustment screws could do nothing. It took a lot of force driving a screwdriver with a hammer between the base tenon and the main casting, after WD-40 overnight. I doubt it has ever been moved since new. Once cleaned up and oiled, again, I had to hammer it back together. It appears to the eye that the tenon and mating slot are slightly dovetailed which wouldn't help reassembly this way. Once back together, the mating parts were still so tight that to get the scale lines approximately to line up, I had to clamp the tailstock base in the vice (Al jaw covers) and use a hardwood drift and large hammer to move the body laterally along the tenon. The idea of using the adjustment screws is laughable. Can anyone shed any light on this? |
Enough! | 14/06/2015 01:38:41 |
1719 forum posts 1 photos | Dunno the answer, Simon, but mine is much the same. To centre it, I've been loosening one screw then using a mallet and drift to I'll be interested to see the responses. |
Bob Rodgerson | 14/06/2015 01:50:15 |
612 forum posts 174 photos | Simon, I too had the same problem when I had an ML7R. Once I set it over to turn a slight taper it was an absolute pig to get back on centre. I woudn,t advise anybody to move the tailstock set over unless it is absolutely necessary. |
John Olsen | 14/06/2015 03:15:07 |
1294 forum posts 108 photos 1 articles | My ML7 is of early fifties vintage. It has never required a hammer and I would be very wary of using one on it. It is of course necessary to back off the screw on the opposite side before screwing one in to move it. It must not be clamped to the bed when you try to adjust it. I have done tapers with it a few times. I would agree that getting it back on centre is a very fiddly job and best avoided if possible. Might be just as fast to make a taper turning attachment. I did borrow one once, much better. Otherwise you can put a centre in a boring head and use that for the offset. John |
Simon Collier | 14/06/2015 05:55:06 |
![]() 525 forum posts 65 photos | Thanks for your responses. Clearly, I am not alone, so that is somehow comforting. Now that I know, I would strongly endorse Bob's advice not to touch it. John, you do not realise how tight this is. Not only do I need a hammer, but a big one, and hit hard (with wood drift, as I said). No grub screw would move this; a one inch bolt might. Some owners must have milled a bit off the tenon or slot to make it usable. I'll try to get it right (with hammer) and forget about it. Or will I have a go at it? Not sure. Simon |
Lambton | 14/06/2015 07:19:21 |
![]() 694 forum posts 2 photos | A few important points about adjusting an ML7 (and Super7) tailstock.
Simon Collier | 14/06/2015 08:24:20 |
![]() 525 forum posts 65 photos | All screws were removed and the clamp bolt nut. I did use a Hyde hammer except with the wood drift. I am going to measure the fit to see just how much interference there is. |
