Plastic material for making casting patterns
Stewart Hart05/06/2015 07:14:11
674 forum posts
357 photos
Hi all
I've seen some ware a plastic for making casting patterns on CNC machines, does any one know what this material is called and where you can purchase it from.
Thanks
Stew
Brian Oldford05/06/2015 07:25:00
686 forum posts
18 photos
Are you thinking of Sikablock? It's available from the likes of http://www.johnburn.co.uk/
I use it from time to time in my professional capacity.
Stewart Hart05/06/2015 07:30:03
674 forum posts
357 photos
Bloody hell that was a quick reply.
That,s the stuff.
Thanks Brian
Stew
Neil Wyatt05/06/2015 07:32:10
19226 forum posts
749 photos
86 articles
Hello Stew, I think they use polystyrene and polyurethane foam in industry.
Brian Oldford05/06/2015 07:40:26
686 forum posts
18 photos
Polystyrene is frequently used as a sacrificial pattern material. Useful for large-ish one-offs. OK for CI but other processes need to be added if casting steel or other materials where the carbon content must be controlled.
Sikablock (and similar from other vendors) is just such a polyurethane material. It's available in a huge range of densities. The lightest has similar mechanical properties to Oasis that used by flower arrangers. The densest could be used to drive nails in with.
Sam Stones05/06/2015 07:53:22
922 forum posts
332 photos
Stewart,
To add a little more to this thread -
Polystyrene – actually expanded polystyrene (or EPS) is a foamed thermos-plastic, which will melt when heat is applied. It is often used as a form similar to the lost wax or investment casting process, melting and burning off as molten metal is poured into the mould.
Polyurethane is generally a thermo-setting plastic, which therefore doesn’t melt when heated.
Try **LINK**
Sam
David Brandon25/06/2015 17:14:42
1 forum posts
I use polyurethane foam for most of my patterns. I use 50 lb per cubic ft. Most signs are now carved from this stuff using 15 lb/ft
