Reducing Bush or Sleeve
James Alford06/05/2015 21:47:06
501 forum posts
88 photos
I have bought a pulley to set up my Flexispeed lathe, but need a plain bush to sleeve it down from a 38mm bore to 16mm for the shaft. Can anyone suggest where I could get such a thing? I have looked, but can find nothing this size. I did buy a taperlock sleeve, but misunderstoodwhat they were for and it does not work.
Alternatively, for a price, would anyone be willing to turn one for me?
Thank you.
James.
John Haine06/05/2015 22:06:27
5563 forum posts
322 photos
How long and how fix to shafts?
James Alford06/05/2015 22:45:20
501 forum posts
88 photos
John,
It needs to be an inch long and secured with a grub screw or even loctite. It is not keyed.
James.
John Stevenson07/05/2015 00:41:16
5068 forum posts
Double check that 38mm size.
As 38.1 is 1.5" and 38 isn't a usual standard size.
James Alford07/05/2015 07:10:25
501 forum posts
88 photos
John,
I have checked and you are correct: it is 1.5". I should have guessed that it would be imperial, really, as the diameter of the pulley is cast intoit in inches.
James.
JasonB07/05/2015 07:26:26
And the shaft is likely to be 5/8" not 16mm.
James Alford07/05/2015 07:30:45
501 forum posts
88 photos
Posted by JasonB on 07/05/2015 07:26:26:
Jason.
 Yes - just double-checked and it is 5/8". I took it at face value that it was 16mm when I picked it up.
So: I now need a bush 1.5" OD, 5/8" ID and 1" long.
James.
Edited By James Alford on 07/05/2015 07:37:22
Edited By James Alford on 07/05/2015 07:37:44
old Al07/05/2015 08:54:58
187 forum posts
Very simple job if you had the pully in your hand. Just bring it round and I will do it over a cup of tea. I cant understand why nobody at the local model club has offered.
James Alford08/05/2015 06:58:53
501 forum posts
88 photos
Old Al,
Thank you for the offer: I have had another similar offer and have taken that one up. The main reason why the local club has not offered to help is because I am not a member. To be honest, it hadnot even occured to me to join.
James.
