Malcolm Harvey | 20/04/2015 17:09:55 |
![]() 30 forum posts 1 photos | Wonder if anyone would be good enough to tell me how they get the ends of their coupling rods circular at the ends? I see LBSC method of putting a pin in the vertical slide or whatever and hand holding them with your hands against the side cutters on a slot drill but this seems a bit hairy fairy scary broken wrist to me. There must be a better method. |
JasonB | 20/04/2015 17:13:28 |
![]() 25215 forum posts 3105 photos 1 articles | Filing buttons, clamped securely to a rotary table then milled, CNC, etc |
fizzy | 20/04/2015 18:23:08 |
![]() 1860 forum posts 121 photos | I do it same as lbsc..Jason, what are those? |
Neil Wyatt | 20/04/2015 18:26:34 |
![]() 19226 forum posts 749 photos 86 articles | On a mandrel in a chuck on RT on mill table, with a toolmaker's clamp attaching it to one of the jaws, or filing buttons for small things. Neil |
Malcolm Harvey | 20/04/2015 18:44:56 |
![]() 30 forum posts 1 photos | I don't have the luxury of rotary tables or CNC. What are filing buttons? Is LBSC's method safe?
JasonB | 20/04/2015 19:00:18 |
![]() 25215 forum posts 3105 photos 1 articles | Filing buttons are just a couple of slices parted off a rod of teh same dia as the outside of your rod end and drilled to the same size as the hole, some people harden them I just use mild steel as it is. You then slip a pin through your rod hole, a disc either side and file away, when teh file hit sthe discs they act as rollers and stop the file cutting any deeper. It may seem a pain making them but keep them and you will save having to make them the next time, you will soon get a good collection Couple of ways to do it in the rotary table
Edited By JasonB on 20/04/2015 19:03:01 |
Malcolm Harvey | 20/04/2015 19:14:30 |
![]() 30 forum posts 1 photos | Thanks for explaining that. Its simple enough even for me |
Bruce Edney | 20/04/2015 20:05:34 |
![]() 167 forum posts 53 photos | I have used some old bearings from HDD recently as filing buttons. These worked great as there are hardened and they roll. |
