Automate the Shutter button
martin perman04/04/2015 20:26:47
2095 forum posts
75 photos
Gentlemen,
My camera doesn't have a delayed shutter timer, technically is does but I have to hold the button down for up to 30 seconds, so I thought that I would replace my finger with an automated device but I have no idea what the thread is in the middle of my shutter button, can anybody help please.
Martin P
"Bill Hancox"04/04/2015 20:42:32
257 forum posts
77 photos
For a mechanical. shutter release.
Bill
martin perman04/04/2015 21:07:40
2095 forum posts
75 photos
sorry forgot that bit, I want to fit a solenoid which is controlled by a timer which can be set to work up to the camera's max of 30 seconds.
Martin P
Ian Parkin04/04/2015 21:44:23
1174 forum posts
303 photos
I would buy a cable release which has the correct thread form already then fit your solonoid on the end of that and decouples any vibration from your camera when the solonoid actuates
The thread is a tapered one ( i assume you knew that )
Neil Wyatt05/04/2015 09:59:24
19226 forum posts
749 photos
86 articles
Sorry Martin, I'm a little confused.
Is it the self timer for delayed exposures or is it the 'B' setting for long exposures?
If the self timer, it sounds like it is broken
For the latter I have a cable release with a locking screw, press in, lock the screw and leave for as long as you want.
Yuo can control the exposure time with a black hat over the lens.
martin perman05/04/2015 13:25:39
2095 forum posts
75 photos
Neil,
Everything works ok, the problem is the idiot operating the camera, I have this problem when using the button or a cable in that I snatch and cause a shake particularly when using the B function which requires me to hold the button pressed for the time required up to a max of 30 seconds so I thought I could make a device to do it for me.
Martin P
Clive Hartland05/04/2015 13:32:12
2929 forum posts
41 photos
I have seen clockwork timers on ebay to fit cameras. Have a look. Which camera do you have?
Neil Wyatt05/04/2015 14:14:54
19226 forum posts
749 photos
86 articles
Martin,
just get a locking cable release, and hold it so there's a reasonable bend in it - that way you won't snatch.
martin perman05/04/2015 16:27:07
2095 forum posts
75 photos
Neil,
Found the answer, went onto Amazon to get what you suggested and found a switch with cable which plugs into the mini USB on my camera which operates the trigger electronically and it also has a lock for the B function so no more snatching of cables or buttons.
Martin P
Bo Sandström05/04/2015 18:38:47
1 forum posts
Search the web for Autoknips, An ancient device that may be what you are looking for
