helical gear supplies
clogs09/03/2015 14:32:17
630 forum posts
12 photos
Hi all, looking for a supplier of Helical gears....prefer from stock....
I need a matched pair between 75-100mm about 20-25mm tooth thickness and
hardened ...
these are to run in mesh one above the other to reverse the direction of the driven gear.....to transmit 2-5hp at varying speeds.....constant load.....
this is to drive a camshaft (4 cylinder petrol) in the past they were driven by ally or even fiber gears meshed with a steel one...
any ideas...many thanks Clogs
Les Jones 109/03/2015 14:53:41
2292 forum posts
159 photos
One possible solution is two sets of replacment angle grinder gears that are sold on eBay. I do not know if any of them would be as large as 75mm (I assume this is the diameter.)
Les.
davidsuffolk09/03/2015 15:00:44
48 forum posts
8 photos
I found Paul Wheeler at Cross & Morse of Birmingham very helpful. 021 360 0155. They have a online catalogue so you might find what you seek there. I ordered a pair of bevel gears and they were delivered the following day.
John Stevenson09/03/2015 15:29:21
5068 forum posts
HPC Gears at Chesterfield.
**LINK** Also do a priced on-line catalogue.
Only problem with stock ears is they are usually pilot bore as they don't know what you want them for and therefore unhardened although you do have a choice of materials.
Bob Brown 109/03/2015 16:37:34
1022 forum posts
127 photos
ondrives list helical gears **LINK** case hardened so bore can be machined to suit.
Bob
